Hi all!
I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to the mids and woofers.
So I pulled out the crossover and found that it has quite the robust crossover. 4 inductors, 4 film capacitors and 1 bipolar electrolytic capacitor. I have attached some photos in case they would be of any help.
I haven't tested the film caps as I did some research online and read that the film caps that ADS used were very high quality and shouldn't be going bad. The electrolytic on the other hand could be suspect. I pulled it out and tested it with my LCR meter. This is a 100uf 100v bipolar cap and when I tested it on the LCR meter (which I zeroed out prior to testing the cap), it showed these numbers:
@ 1 kHz = 99.33 uf / 0.03 esr
@ 10 kHz = 96.1 uf / 0.00 esr
@ 100 kHz = open line
@ 100 Hz = 103.68 uf / 0.5 esr
I tried finding the original specs of this Nippon Chemi-con CE04P capacitor but couldn't find anything on it.
As I said before, I am still learning and am only just starting to scrape the surface of understanding the theory behind these things, so please take that into consideration when reading this post.
So I have a few questions:
Cheers
- Why would it show zero esr at 10 kHz and and open line at 100 kHz but showed pretty high esr readings at 1 kHz and at 100 Hz?
- I'm guessing that the esr is bad since it's reading 0.5 at the high end - am I correct in thinking this?
- What would be a good replacement cap if this is indeed a bad cap?
Cheers
