Re: List of Bad Cap Manufacturers
I hope this isn't off-topic, but I just bought a couple of packets of cheap electrolytics on ebay. One packet was 125 caps (5 each of 25 types, various brand names, all marked 105 degrees C). I tested their ESR, and found that half of them were higher than the limit specified on my ESR meter. One was defective (open circuit). The other packet was 50 caps, all 220 uF 16 V, marked 105 C, and branded Chenxing. For all but one of them, ESR varied from 0.48 Ohms to 0.64 Ohms, where the limit specified on my meter is 0.4. The one exception was 0.96, which I regard as defective.
These results have made me think that the second batch at least, consisted of factory culls: capacitors which failed the factory quality control tests. The first batch may have been something similar but they may have failed other tests rather than just ESR.
From my point of view, I'd be prepared to use nearly all of these capacitors in home projects for use in my own home, provided whatever I was working on would not cause anyone any problems if it failed. However I would not use any of them in a repair for a friend, nor would I give any of them to anyone else to use. To me they are not horrendously bad - I'm old enough to remember when, here in Australia, some of the caps I bought from well-known trade suppliers were considerably worse than these.
