The GOOD Capacitors Thread!!
This is a sticky topic.
    Re: The GOOD Capacitors Thread!!
    Originally posted by japlytic View Post
    I seem to be developing faith in Taicon electrolytics, since most of the series were the same (and some comparable) to the Nichicon units.
    On a 9-year old board, none of the Taicon units were bulging...
    Taicon is hit or miss. I've seen motherboards where every Taicon on the thing was bulged. So, unfortunately, it's not a reliable brand.
      Originally posted by PeteS in CA View Post
      I'd consider Elna a maybe. IMO, Nichicon, United (Nippon) Chemicon, Rubycon, and Panasonic/Matsushita are the top tier miniature lytic mfrs. And Sanyo for their OSCONs (I haven't used their lytics). Elna, Illinois Capacitor, and maybe Teapo would be second tier. The rest of the usual suspects are scary except in really low stress applications.
      Teapos do last quite a while at lower temperatures and stress though. I have many Hipro PSU's (DELL OEM) with Teapo caps and never had a problem so far. They're decent quality, but not the best out there.
        Elnas are good, but since they aren't use as much as many of the other Japanese brands, it's hard to know...because you don't experience as many widespread failures.
          Elna is good but their marketing targets audiophool type things and because of that they cost more than other options.
          Their cost is why you don't see them much in IT type things.
          Mann-Made Global Warming.
          - Dr Seuss
            I actually have a few old computers with ELNA capacitors in the riser cards. They're very good!
            But yeah, a lot of their caps are marketed towards audio.
            I'd say ELNA is better than nichicon, but presumably overpriced. Of course, rubycon trumps them all --> though I've got some 30-year old sanyos in my old analog equipment that's getting along just fine
              Elna better than Nichicon? In specialty capacitors, maybe. In low impedance, high ripple current and long life capacitors? I highly doubt it. I don't know how many years ago I posted what is quoted above, but I'll stay with it. Rubycon may be a bit better on the low impedance high ripple current types; Nichicon and UCC may be a bit stronger on the high voltage, very long life electronic ballast types.
              PeteS in CA
                Absolutely, the ELNA caps in my computers are over 15 years old!
                A lot of nichicons I've seen always seem to get puffy at their vents a little bit. Not always the case, but very frequent (same with chemicon).
                Whereas ELNA is a lot more consistent with quality, I think.
                  That reflects well on what Elna produced 15 years ago. I've worked in power electronics since 1980, and with a few noteworthy exceptions (the Nichicon HMs and HNs in that defective 2003-2004 batch and more recently, NCC/UCC KZG and KZJ) Nichicon and NCC/UCC have been the standard for comparison, and Rubycon and Panasonic are of the same class. My very limited experience with Elna - 20 years ago - was not good. But that was 20 years ago. As others have pointed out, commit a design error or misuse the part, and the very best cap out there will fail quickly.
                  PeteS in CA
                    Here's few pics in support for ELNA quality, from 36 year old amplifier. Haven't measured them (yet) but still going strong with no bulging or serious voltage leaking.
                      Cool.
                      I got a pair of big 24000uF 80v ELNA capacitors too. They are still good!
                      Muh-soggy-knee
                        thats because back then they weren't made in china and the company didn't do any serious budget cuts
                          Elna caps are still good I think.
                            Uranium, you gotta get rid of that avatar...everytime I see it think I have a bug on my screen.
                              It seems Mallory is highly regarded but I rarely see these nowadays. Just a lot of old ones when they used to be their own company. Same with Sprague. (Both these brands were bought by Vishay?)
                              Any comments about Illinois Capacitor - I still see these once in a while, just not frequently. I haven't seen any of these blow up at least, but ESR? I don't know...
                                I had a bunch of NOS Mallory caps way way back in the early days of Badcaps.net (2001~2002) that I bought real cheap. I haven't had any since....
                                <--- Badcaps.net Founder
                                Badcaps.net Services:
                                Motherboard Repair Services
                                http://folding.stanford.edu/
                                Team : 49813
                                Join in!!
                                Team Stats
                                  The old Mallory caps were good, but the new ones are resleeved Teapos.
                                    Look at these babies. Operated many years for a solar installation as a 120V pure sine inverter. Why it is open, is the switching relay finally failed through magnetism of the contacts, causing >single cycle transfer blinking lamps when switching off grid power.
                                    Edit, that goo at the base is hot glue. The entire board is comformally coated, as well.
                                      Nichicon HE caps look decent would you guys agree?
                                        Responded on your other thread.
                                        PeteS in CA
                                          Those must be oooold, or they might be custom. The nichicon GU datasheet says they are white on black sleeve. I am not suspecting fakes at all, just, what is their capacitance and voltage rating?
                                          Muh-soggy-knee
