The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
  • timb0
    • May 2012
    • New Zealand
    #281
    Re: The Hall of Shame - Badcaps Photo Montage
    Wow, interesting that they all blow at the same time, thanks, will start a new post!
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I know this isn't the greatest picture but this was the power supply from a Gateway 900G that wouldn't turn on. All the caps are Samxon GF series, I put a red dot on all the dead ones. I replaced ALL the caps with Panasonic FM and it's working great!
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        #283
        looks like bad thermal design
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          How so?
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Originally posted by Pentium4
            How so?
            The caps are right next to a heatsink.
            Muh-soggy-knee
            • c_hegge
              • Sep 2009
              • 5219
              They are samxon GF series, though, so it doesn't take a heat sink to kill them.
              • mariushm
                • May 2011
                • 3799
                #287
                A lot of switching regulators datasheets mention that the capacitors should be at most about 1 cm away from the chips, to keep the trace lengths small.
                So often, they can't do much about it, the capacitors simply have to be that close to the chips (whatever they are) that's mounted on heatsink.
                I'd say the problem is the layout... they could have tried to move the chip a bit to the left so that the heatsink could have some fins extending horizontally and dissipate the heat better. Problem is there also has to be a bit of distance from the inverters as 700v-1400v can arc over if you're not careful.
                But... it was cheaper for them to use a simple bent bar..the extrusion process for fins on heatsinks is a bit more expensive.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  DON capacitors from an Allied power supply. I'm going to recap it, then I'll post pics of them close up, they died so hard
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    You should dissect them also, and see if that orange gook is all over the inside too xD
                    Muh-soggy-knee
                    • Downward_Spiral
                      • Jul 2012
                      • 37
                      I created an account because it seems many people here have had the exact same problem I have. My Samsung SyncMaster 216BW computer monitor (5 years old) would flicker and hum, then shut down and had to be power cycled several times to stay on. I just ordered the replacements.
                      The caps in the worst condition are the CapXon 820uf 25v. The short 330uf 25v in the back of the first picture (out of focus) has slight leakage as well. My computer room probably gets well over 100 deg.F in the summer if my brother and I are both gaming in here. I wouldn't be surprised if that was part of the cause.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I've had two Samsung 226BW monitors with bad CapXons in their PSUs. Monitor PSUs do tend to run warm, since they don't have any fan or much ventilation to keep them cool, so bad caps should never be used there.
                        • Mike Jenk
                          • Jul 2012
                          • 113
                          Vizio
                          • apraxisz
                            • Jan 2011
                            #293
                            Linksys SD2008 gigabit switch
                            • herita
                              • Aug 2012
                              • 17
                              • France
                              #294
                              oki you guys , today i have gift for you
                              on my table, i have one LENOVO A61 mainbroad with plenty of bad boys
                              so here is the menu, enjoy
                              the whole thing
                              what a shame : 6.3v and 16v:
                              humh ...
                              Beside video controler
                              ps: i don't know the brand name of these caps
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #295
                                They're KZGs, a capacitor series from Chemicon. Their electrolyte is unstable (too much iron?) so they eventually fail in a few years of even moderate use, especially with added ripple and heat. KZJs also fail in a similar manner. All other series from Chemicon are good. Your images are interesting, though - KZGs often fail without bloating, but not so in your account of them.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  I say its time to open up the PSU, seeing that widespread capacitor failure there! :O
                                  Muh-soggy-knee
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Not necessarily, KZG and KZJ will fail like that with a perfectly good PSU.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Ah
                                      but, wow, its like one got sick and they all got the same disease :P
                                      Muh-soggy-knee
                                      • herita
                                        • Aug 2012
                                        • 17
                                        • France
                                        #299
                                        yep, i confirm, the PSU works perfectly, i have checked all caps inside PSU, they all work great
                                        it seems like heating killed those caps on the broad. chipset ATI on north bridge is often so hot.
                                        • iToasterman
                                          • Sep 2012
                                          • 8
