is the below a bad thing to do?
is this a bad idea for a capacitor?
Re: is this a bad idea for a capacitor?
Probably because if it needs to Vent it cant meaning it will likely explode or push the bung out.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Is that card board sleeve holding down the cap?
Not mechanical secured mounting.Never stop learning
What device is that in?Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic
Originally posted by cam4441 View Postwhy's a 16v a bad idea?
it should be [continuous voltage] x1.5.
so atleast 22v - use a 25v cap
Originally posted by cam4441 View Postno its a bit of double sided sticky foam, I think I'll find another way to mount it.
What you don't want to do with caps is seal their top with epoxy or have the whole cap tight against something... which you don't have, so it is okay.
Originally posted by cam4441 View Postit keeps the voltage stable servos glitch and shake without them
Makes me curious what brand that capacitor is. I've seen some sellers on eBay offering cheap low-quality caps for these. But I guess it doesn't really matter that much anyways, since the caps are hardly stressed at all filtering power to the receiver. Even a low-quality brand should last a while in that spot.
Just FYI, though, there is nothing special about those caps. You can easily make your own for a fraction of the price, especially if you have some access to junk electronics like TV boards and such.Last edited by momaka; 04-28-2016, 11:17 PM.
When you said tight against something you mean the top of it and venting is that it would push the bung out instead of venting. If it was to firmly fastened at the top.
the next picture down with the zip tie should be ok?
I'm not sure of the brand but it probably is a crappy oneLast edited by cam4441; 05-03-2016, 03:04 AM.
Originally posted by cam4441 View PostWhen you said tight against something you mean the top of it and venting is that it would push the bung out instead of venting.
The "X" you see on top of the cap is a pressure safety vent. When too much pressure builds inside the capacitor, it will bulge and eventually the vent will slowly release the pressure.
However, if the cap is glued down and the vent is blocked, then the cap will try to push out of the rubber bung on the bottom when pressure builds up (that is, if the cap fails, of course). The difference is that the bung may not always release the pressure in a safe way. So that's why it is important that the cap vent is not blocked.
Originally posted by cam4441 View Postthe next picture down with the zip tie should be ok?
The only note I have about that is to be careful when tightening the zip tie so as not to crush, dent, or deform the cap body. Usually, a cap will still work even if you do. But it could also short out or build up pressure inside.
Originally posted by cam4441 View PostI'm not sure of the brand but it probably is a crappy one
