help
  • chunky35
    • Aug 2009
    • 12
    help
    i am about to start my first recapping on a Aopen ax4t motherboard 85 to 95 percent are bulging capacitors or leaking i have read just about everything here i hope from cleaning to soldering stations how hot so forth my problem now is how can you identifying what brand of capacitor it is some dont even have name on them the reason im saying that my practice board they didnt have a brand on them hope this makes some kind of sense
    thanks chunky35
  • Player2
    • Aug 2009
    • 98
    Re: help
    The brand of the current caps is not really important. What matters are the capacitance (uF), voltage rating, and dimensions in mm (diameter x height). You should replace all of the caps on the board. Make a list of what values and dimensions you need and I or someone else can help you find appropriate replacements.
    If you are really interested to know who made the current caps though, post any logos or codes on the casing. Pics are a big help!
    • chunky35
      • Aug 2009
      • 12
      Re: help
      thanks player2 will do
      • kahlil88
        AOpen MX36LE-UN which replacement caps?
        by kahlil88
        Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
        10-23-2025, 03:14 PM
      • learnmore
        Recommended BGA Rework Stations
        by learnmore
        Hello Community,
        Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
        Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models?
        01-22-2024, 04:53 AM
      • bart64
        ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
        by bart64
        After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
        10-18-2025, 05:51 AM
      • jason123
        Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
        by jason123
        Hello folks,
        New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
        05-27-2025, 07:26 AM
      • SolomonMan
        HP Docking Stations Power Supplies...?
        by SolomonMan
        All,
        I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
        Anyways these docks are HP Model 5TW10UT#ABA.
        Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
        I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
        h...
        05-09-2023, 08:04 AM
