Weird outer shell markings/corrosion (?) on polymer caps
  • Snayperskaya
    • Nov 2015
    • 46
    • Brazil
    Just saw this on another forum. On some caps it looks like a plastic coating is peeling/falling apart.
    Does anyone knows what's up with those caps?
  • brispuss
    • Dec 2012
    • 54
    • NZ
    Re: Weird outer shell markings/corrosion (?) on polymer caps
    Capacitors heating(?)
      • 31131
      aluminium oxidises if it's cratched.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Plastic coating or shrink sleeving peeling due to heat?
        PeteS in CA
        • Heihachi_73
          • Jun 2012
          • 713
          The microscopic fungus(?) that eats aluminum like they found eating away at CDs not so long ago?
          • R_J
            • Jun 2012
            • 9578
            Looks like some kind of insect damage, The aluminum is not touched, it is just the coating that is being eaten.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              ¿las cucarachas?
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • PeteS in CA
                • Aug 2005
                • 3581
                ¿las cucarachas?
                Barata?
                PeteS in CA
                • Loki_Fido
                  (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                  by Loki_Fido
                  Hi folks,
                  This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                  I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                  BIOS - XMC 25RU128CH10 (1.8v)
                  What the heck is this? I looked all over the MB. This is the only bios.
                  When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                  03-20-2025, 01:57 AM
                • Topcat
                  Topcat's First Weird Project of 2023!
                  by Topcat
                  2022 was crazy busy around here....I really didn't get to play with many of my toys.....
                  Lets start out 2023 a little better on that front, beginning with a bad Quadro FX5800....
                  ...but this is what I was after, the outer shell...
                  The casing surrounding the heatsinks is plastic....however the backplate feels like magnesium or some alloy....not completely sure, but it's not plastic.
                  This will make more sense as the project develops....especially what weird build it's going in...but HAPPY 2023!!
                  01-01-2023, 03:32 PM
                  APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                  This started a few days ago and does this about every 8 hours
                  After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                  The battery backup is about 3 or 4 years old
                  Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                  06-02-2024, 02:30 AM
                • ugamazing
                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                  by ugamazing
                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                  04-10-2024, 08:06 AM
                • estabilito
                  Acer Nitro AN515-55 weird behaviour on startup
                  by estabilito
                  Hi, I've just repaired acer nitro an515-55 with specs:
                  i7-10750h, rtx2060.
                  Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                  After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                  i've tried different bios, different vbios and same behaviour - clean windows install too.
                  Do you have any idea?
                  08-13-2025, 02:52 PM
