Does higher voltage tolerance mean more robust?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Where electrolytic capacitors are concerned, when you're replacing them on a board that's say ... 20 years old...
    Let's say we have a 10uF cap that is rated at 25 Volts.
    If I replace that with a 10uF cap that is rated at 50 Volts, would that 50-volt cap be more resilient in terms of longevity and being able to handle more stress than the 25V cap ... assuming the cap will live a normal life and not have any defects throughout its life.
    Does upping the voltage rating of a cap make any difference at in terms of longevity and over all "robustness"?
    sigpic
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Does higher voltage tolerance mean more robust?
    It depends on the kind of circuit, and type of cap used. If it's used for power filtering it's usually ok to go fairly higher voltage, but the quality of the cap is also huge factor. Other than that, it depends. Others here should give you a better answer
    • AleXis6
      • Feb 2021
      • 69
      • Belarus
      If you change within the same series, most likely yes.
      Look at the datasheet, it usually specifies the runtime at operating voltage and temperature and this value in hours often correlates to the size of the capacitor.
      i.e. if you put a capacity of the same series at a higher voltage, its size is probably larger and it is likely to indicate more hours of failure (but not always).
      see the attached picture of Nichicon HE datasheet, it even describes that higher voltage -> more working hours
      [IMG][/IMG]
      • tvguy12012012120
        Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
        by tvguy12012012120
        This is the zombie UN55NU6900F I wrote about in this original post.
        It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
        The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
        1. What could cause the standby voltage to be 1V higher than expected
        2. Is this a problem
        3. Could it have led to the failure at RM819, or was that...
        02-12-2025, 11:22 AM
      • UserXP
        Transformer producing higher voltage than rated
        by UserXP
        Hello, people.
        i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
        So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
        09-02-2025, 12:42 AM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
