Biostar m6tba v1,5
  • Chris1992
    • Apr 2005
    • 561
    Biostar m6tba v1,5
    A biostar m6tba v1,5 belonging to my school is in a system with celeron 433 in slotket, 256mb sdram. I upgraded with new HDD, PSU, and video card and now it will not boot. All fans spin up, but no video and no beeps. It will remain in this state until turned off. I have tried booting w/o HDD, optical, and with case fans disconnected (normally connected to MB). ideas?
    The great capacitor showdown!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Biostar m6tba v1,5
    Well, does it boot with the original components?
    Maybe the board is only AGP 3.3v and you used a 1.5v AGP card?
    • Chris1992
      • Apr 2005
      • 561
      I used a Diamond SpeedStar A50 AGP card, is SiS 6326 chipset. I haven't checked with the original components, the old HDD was dead.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        slotkets can cause lots of trouble.
        check it first.
        • linuxguru
          • Apr 2005
          • 1564
          1) Slotkets come in different varieties with small (and crucial) differences in the reset signals, bus arbitration signals, etc. Make sure you have one that will work with a Mendocino Celeron.
          2) The BIOS may need to be upgraded to support the microcode update for the Socket-370 Mendocino Celeron. Note that there separate microcode updates for the Slot-1 and Socket-370 Mendocino CPUs - you need both to be able to support the Mendocino in a Slotket. If you have an Award BIOS, you can add microcode updates to it using CBROM and similar utilities even if there's no official BIOS upgrade from the manufacturer with support for the Mendocino/Katmai/Coppermine.
          • linuxguru
            • Apr 2005
            • 1564
            Oh, BTW - Biostar is big on those green Jackcon and black Teapo caps. Replace *all* the Jackcons first, even if they're not bulging, and optionally the Teapos (which should be OK, but not great).
            • Chris1992
              • Apr 2005
              • 561
              It was working before I overhauled it, so the BIOS and slotket support Mendocino Celerons. The board has no Jackcons, it has Choyo, Sanyo, and Teapo tho.
              • linuxguru
                • Apr 2005
                • 1564
                Clean the Slotket edge contacts with isopropyl alcohol and reseat it firmly - there's very little by way of large caps on a slotket, so the Vcc/GND contacts are critical.
                • AK0R
                  • Mar 2005
                  • 204
                  The motherboard is AGP 2x, as is the SpeedStar A50, so this shouldn't be an issue. However, Per's point is valid. Does it POST with the original video card? Could it be a problem with the A50 (the motherboard "sees" a video card installed, so it doesn't give the "no video" beeps, but the card is still bad)?
                  • Chris1992
                    • Apr 2005
                    • 561
                    I tested the card in other board (soyo SY-5ehm) and it worked.
                    • emil_t
                      RTX3090 working fine but fans not spinning
                      by emil_t
                      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                      04-12-2024, 06:54 AM
                    • b-slayer
                      Asus Strix-G15-G513RM fans don't work
                      by b-slayer
                      I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                      The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                      (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                      (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                      ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                      09-04-2025, 04:58 AM
                    • JayPoorJay
                      Hot Water Rad - A Few ECU Fans and a Timer Switch
                      by JayPoorJay
                      Good Afternoon, Good People.
                      I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                      I REALLY would appreciate y'alls help.
                      This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                      10-29-2024, 12:54 PM
                    • selectivetao
                      Request for Boardview/Schematic - Biostar B660-T Silver Motherboard
                      by selectivetao
                      Hello fellows,
                      I am putting a feeler out for a schematic (or ideally boardview) for the Biostar B660-T Silver motherboard.
                      I had let my guard down and decided to trust the Biostar supplied Windows based BIOS flash tool, only to find that the system would not POST upon restart.
                      no problem I thought - I would just flash using my trusty CH341 and be on my merry way.
                      Upon inspecting the board and locating its Winbond NOR, I found it in a rather precarious spot nestled between the RAM slots and PCIe slot and right next to a rather meltable-looking...
                      12-13-2024, 09:37 PM
                      Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
                      Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....
                      10-31-2024, 02:29 PM
