Since my computer doesn't run properly with more than 128MB of RAM, I need to reduce the memory usage of Windows. The computer came from the fatory with 32MB of RAM, but I am running out of memory with 128MB of RAM. When the computer is first booted, 50MB of RAM are free, which seems low. After running some programs, the available RAM decreases to between 2MB and 20MB. This is not enough to prevent the computer from using virtual memory when a program is running.
The computer runs a modified version of Windows 98 that supports USB storage devices. I need Windows 98 for some old software that does not run under a newer version of Windows.
Contrary to popular belief, "unused" RAM is wasted. RAM is supposed to be used. On the other hand, the early versions of Windows had a poor RAM usage algorithm, because back in the day you were lucky if you had over 32MB.
