Trying to Determine if Bad Caps is Really The Problem
  • ASUSP2B-D
    • Mar 2006
    • 30
    Re: Trying to Determine if Bad Caps is Really The Problem
    I'm using a Presidian Personal Internet Communicator to get online; it is basically just a "box" and not a computer; a closed system using Windows CE for an OS that does not allow download, upload, or updating of any software by the user, just the ability to get online and do research/email. It has no drives and all udating is done through the ISP.
    On one hand it is great; on another, frustrating to not be able to download/upload anything!
    Hey, I hope I'm not wearing everybody out w/my multiple threads... just trying to solve the problems. :
    Thanks again for taking a look at the issues
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      caps can be leaning when they are installed or get pushed when you install the mobo. it does not always indicate badcaps.
      can you install xp without your pci cards and then add them one by one after xp is installed.
      • AK0R
        • Mar 2005
        • 204
        Originally posted by ASUSP2B-D
        4. I can't test the mem untul I can get online, or find somewhere to burn an online test to disk and run it in Safe Mode.
        Feedback, PLEASE!!!
        Memtest86 and/or Memtest+ is/are not run on-line or from Windows. You download the program, install it onto a floppy or CD (depending on which version you got), then reboot with the floppy or CD, and the program runs automatically. I've attached the latest version of Memtest86 (for use with a floppy) from www.memtest86.com; I've had problems with the Memtest+ program.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          user is only online with a ce internet device, no download.
          • ASUSP2B-D
            • Mar 2006
            • 30
            Hey, Thanks for posting that file; I'll get to it and give it a try and then I'll let you know the results.
            Good to know on the caps issue; Thanks for telling me that!
            As for removing all pc cards, yup, I've done that; all except for an extra "easy parallel" card that I seem to keep forgetting is in there... still no progress w/a skeletal system; I think I may go ahead and remove that par card and try again w/install...
            HardwareAnalysis.com has a long list of folks who have encountered this problem w/XP Pro (Splash Screen freeze). It isn't easy to make out what worked for people and apply it to my situation, but the good news is that they have tried everything suggested here and seem to have all concluded the prob is w/installing OS software rather than a hardware problem. Still doesn't help to know what the bleep to do next that will get this bleeping thing to boot up, but I guess it narrows things down (or helps to!)
            Alright then... I'll keep working on the prob....and keep y'all in the loop; much gratitude guys...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #26
              whats that? doesnt your board have parallel port? recommend to install without that it may be causing probs
              anyway if others have the same probs and no solution i would look for another board on ebay or if any of the members here put something up for sale. you should be able to pick up a nice 815 chipset with an 866 or whatever cheap if you want to keep your ram or otherwise an 845 with p4 but needs ddr also. personally its not worth running 98 anymore especially if you are on the net (bad security)
              • ASUSP2B-D
                • Mar 2006
                • 30
                #27
                sure my board has par port; it is just an extra! (a vintage leftover, one might say...)
                Yup, definately am considering another board... which one, don't know... suggestions are always welcome
                Is that Guiness I see in that glass?
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  definitely take it out before you install xp it could cause problems. try again to install without it.
                  if you want to buy a new board tell us you country and your budget
                  • ASUSP2B-D
                    • Mar 2006
                    • 30
                    #29
                    We have lift-off!!!! Yeahhh!!!!
                    Willawake, you did it! I took out that extra par port card (don't know why I kept missing it), reformatted the HD, did a clean install of XP Pro and it worked like a charm!!!!!
                    _THANK YOU_!!!!!!
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      #30
                      no problem
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        That is pretty logical, the computers own parallel port prolly had the same memory address as the one you put in... (0378 - 037F) Change it to another memory range and you will prolly be fine...
                        You can probably do that on the add in parallel card too via jumpers if you want to go that route...
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
                        • Gibon378
                          Problem with stopping audio and video for no reason
                          by Gibon378
                          PC Specs:
                          • CPU: Ryzen 5 1600
                          • GPU: GTX 1080 Palit JetStream
                          • MOBO: ASRock ab350 PRO4
                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                          • PSU: XFX 650W (don't remember what model)
                          • OS SSD: ADATA SP920
                          • OS: Windows 10 21H2
                          Problem description:
                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                          11-19-2022, 09:41 AM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
