Yes, that Pentium. Here's a real trivia question for you folks.
Along with all the other spring cleaning and reorganization underway, I decided to give the faithful old Packard Bell (with a brand-new-for-1997 Pentium MMX) some love. Still got some of its factory fresh smell inside, but there was still a tiny bit of dust in spots, a bit of grime on the case, and I also had some other objectives in mind (such as: How do you tear this infernal thing down when you need to?) I also thought that it'd be a good time to replace the thermal paste, having seen how the paste in a mid-'90s Power Mac turned to chalk. But this stuff was still good. Too late to put it back, though.
Between the Pentium and the heatsink I found a little silvery plate - could be aluminum. This is most curious.
I thought that maybe this was used to smooth the transition from the CPU to the heatsink, but that doesn't make sense to me since the heatsink's mating side is not really uneven. On top of that, it's another layer for the heat to travel through and that extra distance might end up retarding the heat flow somewhat - or is this just modern thinking based on having seen too many thermal paste reviews?
My other explanation is that the application at the factory involved simply placing this piece of aluminum, with paste applied to both sides already, on top of the CPU, and then putting the heatsink on top of that.
Anybody know what's going on with it?
I still have half a mind to reverently put it back in place there, just for old times' sake...I'm sure I'll still be running afoul of Murphy's Law if I put it back in upside down, though!
