Just to ask here... I am from era where every port is working initialy... in now days I see there is graphics depend of version of cpu... So, I have desktop mb ga-f2a68hm-ds2 with no graphics on onboard vga port... with external graphics card produce picture, is ok. I found that might be because my cpu athlon x4 845 has no "graphics in it", but from mb datasheet is mentioned that have onboard graphics... So, is there some sign, where or what to look, to know if the mb vga output is faulty, or simply disabled by cpu inability? Proper confused...
new ga-f2a68hm-ds2 motherboard with no vga output
I make some test with and without external graphics card and logicaly conclude that is everything just what have to be (not display on mb onboard vga and dvi port), so please, can you explain me briefly how is that supposed to work, is that ports use resource from external pcie graphics card, or only from cpu with integrated graphics in it?
Originally posted by harp View PostI make some test with and without external graphics card and logicaly conclude that is everything just what have to be (not display on mb onboard vga and dvi port), so please, can you explain me briefly how is that supposed to work, is that ports use resource from external pcie graphics card, or only from cpu with integrated graphics in it?
Thank you very much for answer. Please can you explain me just one more thing: how can be determined if some mb with vga onboard port need cpu with integrated graphics to output (or something other go wrong), is there some procedure, steps or date code, etc from where motherboard are produced uncompleted? This topic is very new to me, trying understand how to aproach no vga output problem if there is "no problem".
Originally posted by harp View PostThank you very much for answer. Please can you explain me just one more thing: how can be determined if some mb with vga onboard port need cpu with integrated graphics to output (or something other go wrong), is there some procedure, steps or date code, etc from where motherboard are produced uncompleted? This topic is very new to me, trying understand how to aproach no vga output problem if there is "no problem".
In the case of your FM2+ socket motherboard the "A4/A6/A8/A10" branded CPUs have integrated GPUs and will output video from the motherboard's video ports, while the "Athlon" branded CPUs lack integrated graphics, and will only work with a dedicated GPU, and the video ports on the motherboard will not work with one of these CPUs installed.Last edited by dmill89; 03-02-2025, 01:46 PM.
