Network sharing problems
  • pentium
    • Mar 2006
    • 2778
    Okay, let's do this again since the last thread went down the drain.
    My friend recently wanted me to recover files off a hard drive he had and after I plugged the drive into my server I discovered that there was stuff on that drive I could not even pack on to a dvd. We came to a decision that I will just share the drive using the VPN program Hamachi and from there he can copy all the files he wants off the drive and then I can wipe and keep the drive.
    The problem is that while most files can be copied, quite a few are locked because we do not have permission to even view them anymore.
    The first thing I did was reset the permissions for the entire drive and made it so accounts "everyone" and "Hamachi" had full read/write control on the drive.
    It did work to a degree but even after that initial change of permissions there are still pockets of files that refuse to have their permissions changed unless I go and manually do it and I don't have the time to do it to all the files.
    Can I get some help here?
    Find Nedry!
    Check the Vending machines!!
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Network sharing problems
    Well, what I usually do in this instance:
    Go find a computer with Linux installed. It tends to ignore all the windows permissions. Pop the case off, plug the drive in, boot up, copy files.
    If you don't have Linux installed, download the latest version of Knoppix, and start it off a CD. I believe it will also ignore windows permissions, and automatically mounts NTFS and FAT partitions.
    Of course I dont know exactly what you're trying to do with the VPN, that could kind of throw a monkey wrench into the whole thing. You might try using Knoppix to copy the files to your server's HD then you can do whatever you want with 'em.
    Just my thoughts.
    A man convinced against his will is of the same opinion still.
    • pentium
      • Mar 2006
      • 2778
      That's one of the first things I have tried but:
      a) ubuntu HATES hamachi
      b)while the drive mounts and I am able to view files, I am not allowed to move or even copy files.
      Seriously, just tell me how to reset ALL the permissions on the drive and I will be happy.
      Find Nedry!
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        If you are lucky, under Windows and with a Fat32 partition, you can simply copy everithing; a bit harder with a Ntfs partition: you log on as an administrator user and take ownship of all directories and files you need to copy. Remember that Windows Acl is quite cucumbersome at first glance: e.g., you have to set different permissions to write a file, to read a file, to reach a file and to pass through all folders containing it. Moreover, Windows XP Home can set them only in Safe mode; XP Pro and any Vista shouldn't have any limit.
        A tool like Acl View may be useful, since it can preset some settings and works fine on XP Home too, without the need of booting in Safe Mode.
        Zandrax
        Have an happy life.
        • pentium
          • Mar 2006
          • 2778
          Okay, the drive currently has a horribly corrupted copy of XP (believe me, there is no way I can boot this drive) home on it and it's partitioned as an NTFS drive.
          Whenever I attempted to modify permissions on the server, I was the administrator/owner. What I want to do since there is nothing sensitive on the drive is make it so that everyone can get full access to the drive and do whatever they want with it (EG. anybody can read/write, view, modify or delete files)
          Find Nedry!
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Hmm: perhaps Acl View may work for you. Select the drive and press the "Wizard" button (a Xmas tree near a wand): in the new windows, apply settings to "This folder, subfolder and files" and select everything (Read, Write, Execute, ...), then confirm: never tried (changing ACLs this way is a bit dangerous on a working partition because Windows may be not too happy, it should be safer on a data-only drive like your), I hope it works.
            Zandrax
            Have an happy life.
            • pentium
              • Mar 2006
              • 2778
              Will it work on windows 2000 server?
              Find Nedry!
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Yes: Windows 2000/XP/2003. I think it works on server versions too.
                Zandrax
                Have an happy life.
                • pentium
                  • Mar 2006
                  • 2778
                  Well then we will have to wait until the system completes it's weekly backup cycle. That's going to be at least an hour.
                  Find Nedry!
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    Ok. Sorry but I can't wait for long, it's about 1 am here: if you need it, I can help you tomorrow.
                    Zandrax
                    Have an happy life.
                    • pentium
                      • Mar 2006
                      • 2778
                      Well then....
                      Go to bed or else you will be living off coffee tomorrow.
                      I'll try to figure it out until then.
                      Find Nedry!
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        Well then....
                        Ok: I'm a caffeine addict, but never more than two cups a day.
                        Zandrax
                        Have an happy life.
                        • bgavin
                          • Jan 2007
                          • 1355
                          You might have better luck with BART-PE. It tends to ignore permission issues on drives that are not its boot drive.
                          For example, I copied a customer directory structure to my server during a service operation. One of the folders is named "con" which is a DOS reserved name. I cannot delete this folder from the server, so I boot BART and delete it manually.
                          For the rare instances where BART refuses to talk to the disk, I use NTFS4DOS. This is an NTFS r/w driver that boots off a DOS diskette and allows full r/w access to NTFS volumes. You can kill or copy ANYTHING on the disk using this app.
                          • pentium
                            • Mar 2006
                            • 2778
                            As soon as I put something warm on I went into the server room (It's freezing in there!) and gave it a shot. I think I did work it as a few moments after I mailed my friend to try again he logged in and my internet connection suddenly started to get raped.
                            Find Nedry!
                            • toastygoodness
                              • Jul 2005
                              • 813
                              i know this sounds really weird, but when I used Vista on a new compy, it could use my old hard drive's files and ignore the permissions/change the permissions. Awkward.
                              • BOSCHNJAK
                                by BOSCHNJAK
                                ABOUT ME INTRODUCTION FILE
                                2
                                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                2022 BEV, PROJECT ?
                                2021 BEV, PROJECT ?
                                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                12-28-2023, 02:09 PM
                              • davg
                                Home network connection problem
                                by davg
                                I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                03-06-2021, 07:13 AM
                              • japlytic
                                Maximum speed should be marked on network ports
                                by japlytic
                                I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                12-19-2024, 05:04 PM
                              • howardc64
                                Samsung UN55JU650DF network/streaming problem
                                by howardc64
                                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                07-09-2025, 12:44 PM
                              • jean luc ferre
                                laptop hp g72 b52sf screen problems
                                by jean luc ferre
                                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                06-07-2025, 03:27 PM
