Hi guys,
Got this cheeky little wireless alarm system going, now i live in a 3 story town house, have sensors 1st, 2nd, 3rd, master unit on 2nd mid passage between the two stair cases (if you know what i mean) take the unit away from the top of the 1st floor stairs (mid passage) towards the bottom of stairs leading to 3rd floor, wont pick up the "door" contacts, but will the PIR sensors???? and same applies if the order was reversed for the upstairs (3rd floor) sensors????
Had the main unit apart, with wire attached to the 2 solid copper wires "ANT" and a "spring" type what i can only assume is an "ANT" because both the door contacts and PIRS have one, only the PIRS a thicker and longer. I also used the aerial off of a wireless cctv receiver and that made no difference on what wire or spring it touched.
can someone help me out here, it's doing my nut!! i moved the unit slight closer to the 1st floor, it picked them up sitting on my switched on central heating radiator and the 3rd floor, picked it up some 2-3 foot and screwed to wall and now won't pick up 1st floor door contacts, only difference was i had the back of the unit off.
any help much appreciated!!
