best cheap/free scores 1.1
This is a sticky topic.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: best cheap/free scores 1.1
    Originally posted by ruky con
    I got 5 HDDs for free a while ago but i thought i'd post them anyways.
    Drives are...
    Seagate ST3300831SCE 300GB
    Seagate ST3500312CS 500GB (made June 2012)
    Western Digital WD800BB 80GB
    Maxtor D540X-4K 40GB
    Maxtor E-H011-02-3056 40GB (made February 2003)
    I'm not sure if any of these work because the only PC i have that can test most of these drives needs both a PSU and motherboard recap. But maybe someone can tell me how good they are or if they suck at all.
    (These were all salvaged out of old DVRs)
    Chunk the Maxtors, check the Seagates, and chances are that the WD drive is fine.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by Uranium-235
      965 ee is two cores WITH hyperthreading.
      So, basically like a ancient prehistoric Netburst version of Core i3 3225.
      https://ark.intel.com/products/65692...ache-3-30-GHz- ->2 cores with 4 threads
      And of course, Ivy Bridge hardly consumes anything. Ivy Bridge gets a bad reputation for questionable TIM for the IHS...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        #3343
        no the i3 is much more efficient, even an i3 clarkdale beats the piss out of it without the insane heat and power consumption.
        you can buy a delidder on ebay for a few bucks, but be careful with the heatsink so it dosen't crush it
        alternately, you can buy a copper lid to replace the aluminum one
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          WHen Maxtor merged with Quantum, they became pretty decent drives. Maxtor got its bad rap back in the P-classic days, their latter stuff was ok.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • RJARRRPCGP
            • Jul 2004
            • 6304
            When? In 1995 or 1996?
            Arc A770 16 GB
            • RJARRRPCGP
              • Jul 2004
              • 6304
              That's what I mean.
              Arc A770 16 GB
              • RJARRRPCGP
                • Jul 2004
                • 6304
                I never confirmed any Maxtor as bad as those "slimeline" Maxtors!
                Arc A770 16 GB
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Post-2000 with the DiamondMax series?
                  sigpic
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Yes!
                    Arc A770 16 GB
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      Yes!
                      Makes sense. Want the full backstory behind it?
                      sigpic
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Yeah, go ahead.
                        Arc A770 16 GB
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          I think what happened is as follows:
                          In 1995, Quantum found a bunch of old MFM platters sitting in a warehouse somewhere and decided to put them to use. Thet did so by recoating the platters with a new magnetic coating compatible with their drives. They produced a new model of drive using these platters, and called it the Bigfoot series, because these drives were using old, large platters from the late 1980s/early 1990s, thus, had to be 5.25" to accommadate the larger platters.
                          Soon after, the new coating started flaking off, causing drive failure. The new coating flaked off because the platter surface was never sanded clean of the old MFM coating. As a result, Quantum's reputation went through the floor.
                          In late 2000, Quantum sold it's HDD manufacturing division to Maxtor. Maxtor decided to rename the Bigfoot series of drives to the DiamondMax series. They actually began cutting the old MFM platters down to size to fit the smaller 3.5" drives. They were still recoating the old MFM platters. As a result, Maxtor drives began failing like crazy. Not to mention the fact that the manufacturing facilities Maxtor was using weren't the best. As Maxtor's reputation began to dwindle, Maxtor decided to sell out to Seagate in 2006.
                          In 2006, Seagate acquired Maxtor. Seagate shut down some of their factories, and continued to use the cut down MFM platters that were recoated. Of course, the coating failed, and Seagate's reputation went through the floor. They eventually used up the old MFM platters, and their reputation recovered. Seagate continued to shut down factories producing high quality drives, and as a result, Seagate's drive quality went down. Then the Thailand flood occured in 2011, temporarily disabling that factory, which was their highest quality drive producer. Eventually, the factory was reopened, but Seagate's drive quality has never quite recovered.
                          sigpic
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            The Maxtor standard 3.5-inchers were immune, especially the 5K 80 GB I got in 2002 (also made in 2002) and the 2005 6Y060P0 (60 GB 7K) that I got on June 2, 2005, were immune!
                            And the Seagate-trashgate scandal, was with the Barracuda 7200.11, which was well before the Thailand flooding!
                            Arc A770 16 GB
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              #3354
                              Got these for free from a friend:
                              PCCHIPS M848A Rev2.1 board - working, have flashed DFI 748-AL BIOS on it though
                              Delux ATX-500W P4 - unironically a nice unit made by Delux. I'll put up some pictures in the PSU build quality later these days as I'm currently waiting on a super nice retro package - two SS7 motherboards, a Acorp 5VIA77 and a LuckyTech/SYE P5MVP3.
                              Main rig:
                              Gigabyte B75M-D3H
                              Core i5-3470 3.60GHz
                              16GB DDR3-1600
                              Samsung SH-224AB DVD-RW
                              Delux MG760 case
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                I have both PCCHIPS M848A V2.1 and V5.0. I have been looking for a new BIOS update for the 2.1 version with no success as yet. Do you have a copy?
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  #3356
                                  Don't have any. I actually gave up searching a updated BIOS and instead flashed the DFI 748-AL BIOS on it. The only problem it has (although it seems to be ignored by the board) is the thermal readings are bogus in the BIOS. Otherwise it boots fine and works fine.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    #3357
                                    Yet another Z800 (single xeon, 48GB, 2x1TB, Quadro FX4800) but missing two (of 4) drive sleds. I think that's the fourth (or fifth?) one of these I've rescued in the past several months...
                                    And, a Surface 2 (?) that "has some issues" (so I'll probably just pull the keyboard off and recycle the tablet)
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      #3358
                                      'Tis the season for UPSs. By my count, 16 hiding on the first pallet (under the monitors). And, guesstimate another 32 on the pallet behind (I forgot what else was under the shrink-wrap).
                                      But, they're little dinky ~500VA units -- no dount for individual workstations in an office environment. So, pass them through to the scrapper... (fair bit of reclaimable lead in all those batteries!)
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        Nooooooooooooo
                                        sigpic
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16956
                                          I could use a few of them....4~6 of them would be lovely for some security system stuff around here.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
