Re: best cheap/free scores 1.1
Actually, there's flux on the board so somebody tried to fix it but failed.
Scored today a Raidmax RX-500XT so I can test the GTX660 Ti I have. Hope it can power it up at least.
EDIT: Seems like the GTX660 Ti is dead as well I get the 1 long 2 short beep on startup on my DFI)
Also opened up the Raidmax. Figured out the OEM being Guangzhou Sanyang (Pangu Power) and looks like a pretty good PSU.
The only cut corners I can see are the obvious cap choices (ChengX 820uF 200v primaries and the rest is AsiaX) and the AC receptacle doesn't have any additional filtering.
Otherwise, a few good points I have seen in it:
-fairly thick heatsinks (not Hipro grade thick, but good enough to not be a gutless wonder)
-VIPER22A chip for 5vsb
-UC3845B chip PWM controller
-8A fuse
-Weltrend WT7502V PWM
-cool grille for the fan (12cm)
-probably the BIGGEST output torroid I've seen in a PSU that is NOT FSP/Delta/AcBel/Hipro
-2x20A rectifiers for 12V in parallel
-2TF topology if I'm not mistaken
Guess it's a good PSU overall. The only things to do to it is add some line filtering (they put the silkscreens quite weird tho) and recap the PSU (I have a whole PS3 PSU from a dead CECHH04 to gut so that covers me good in the cap section, it's full of Nichicon and Chemicon caps)
Originally posted by momaka
View Post
-8A fuse
