MacOS: R|W Programmers like CH341x BINs..?
For years I tried figuring out how to R|W BINs from my CH341x programmer.
From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years. I'd expect many here figured it out (easily), but in case not ... It's one of the few forms of "how-to" remuneration I can GIVE BACK. This group is both GENEROUS & literally BRILLIANT / GENIUS!!! This may be the easiest means to copy-paste: Code:
SERIAL -to- USB - CH341 ROM (MacOS): READ+WRITE to SERIAL to USB (eg: CH341's) BIN to MacOS: Skip commands you already installed. To check if a cmd is already, use: "which ____" Bash replies with the installed version. (see attachments) Install xcode xcode-select --install Relocate xcode sudo xcode-select --switch /Library/Developer/CommandLineTools Install HomeBrew /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)" Install cask brew install cask Install Ruby brew install ruby Install flashROM: brew install flashrom List Programmers: sudo flashrom --help *flashrom --help shows the syntax for available devices at the bottom.* *The references to ch341a_spi refers to the programmer I'M USING* Verify reader: sudo flashrom -p ch341a_spi ROM Read: sudo flashrom -p ch341a_spi -r <~/name.bin> ROM Write: sudo flashrom -p ch341a_spi -w <~/name.bin> I believe the T203 reader uses the CH341a Protocol ... And also showing screenshots of this working. That said, everyone seems to dislike the CH341 ... and while I have other windows options (RT809F, etc) ... are any of the compatible devices preferable? Thanks. |
Re: MacOS: R|W Programmers like CH341x BINs..?
PS, reading the T203 ROM command was:
sudo flashrom -p ch341a_spi -r 2018MBP.BIN In which the file was READ to ~/2018MBP.BIN And to WRITE the file use: sudo flashrom -p ch341a_spi -w 2018MBP.BIN I'm sure people have already discussed this utility here, but, just in case... |
