Strange Power Supply Behavior on Skyworth 55U5A14G
2 Attachment(s)
Hi, I have a 55 inch Skyworth tv that has a visible standby light but won't power on, Usually this fault is indicative of a bad main board but I went to test the power supply just to make sure of that. The power supply output has 14 pins (see image attached), here are my readings when the main board is connected to the power supply (PSU model: L5R021 ,I cannot find much info about it as it is not popular):
22/12v - 12v 22/12v - 12v GND - GND GND - GND 12V - 12V 12V - 12V GND - GND GND - GND NC NC STB - 4.66V NC ADJ - 4.98V ENA - 0.05V This is already a little confusing to me, first off I do not understand how 12v is at the output, isn't the enable pin practically at 0 volts? What is ADJ? and The STB seems a little low to me. The following are the readings I get with the main board and backlight connector disconnected from the PSU. 22/12v - 12v 22/12v - 12v GND - GND GND - GND 12V - 12V 12V - 12V GND - GND GND - GND NC NC STB - 0V NC ADJ - 0V ENA - 0V How come STB is now completely gone but the 12v remains still? STB should always maintain a constant voltage even when the main board is disconnected correct? If I have 12v at the output always, is the missing STB when it is disconnected an issue? Could I just buy a replacement main board and it would work? Forgive my inexperience but this all seems a little too confusing for me, any help would be very much appreciated!! |
Re: Strange Power Supply Behavior on Skyworth 55U5A14G
This is an always on power supply that outputs 12 volts at low current, The stb pin voltage is supplied by the main board and turns on the pfc circuit etc on the power supply so it will operate at a higher current to operate the tv/backlights etc.
The main board will likely have a 12 volt to 5 volt regulator. The STB pin is the same as a PS_ON pin. |
Thank you!
So then STB should change state when you push power button? What is ENA for?
ENA - enable backlight
I see, I had them mixed up. I thought ENA was for the PSU enable not backlight, i will buy a new main board and replace it. The PSU seems fine at this stage
