Lenovo T14 nm-c931 1th gen intel 10th
    hello,
    I have
    Lenovo T14 nm-c931 1th gen intel 10th with a difficult problem.
    everything like normal when installing a new fresh windows.
    but the problem is in the first step of configuration.
    when I skip the network connection there is no problem.
    bu when connect to a network, laptop is automatic connecting to a compay.
    laptop has no bios password.
    i have change the serial number
    i have program another bios with original ME.
    i cant find the correct ME for this model
    bu no luck.
    i share the the backup.
    can someone clear and rebuild the original bios?
    Re: Lenovo T14 nm-c931 1th gen intel 10th
    Originally posted by osman68i View Post
    hello,
    I have
    bu no luck.
    There is no computrace
      Your serial number ? Your marchine type ?
      Become a Badcaps supporter
      Thanks to all supporters.
        Hi Hoaca,
        I have tested this bios with same result.
        I install new os.
        when connect to a network, laptop is automatic connecting to a company.
          Hi Hoaca,
          I install new os.
          Sorry, I have no other solution. Maybe the other one else will help you. Good luck.
            hello,
            I have
            bu no luck.
            Its Mdm.
              Originally posted by imranromi View Post
              Its Mdm.
              i have changed serial number.
              abosulute software (antitheft) is permanently disabled.
              imranromi how can i change the mac adres?
                Abosulute software (antitheft) is permanently disabled.
                Imranromi how can i change the mac adres?
                  thank you hoaca,
                  I will try and let you know the result
                    thank you hoaca,
                    @osman68i
                    Any results with changing mac address directly in BIOS?
                      same result,
                      i think there is a part in the mec.
                        same result,
                        can you disable the wireless card in the bios setup and try usb stick wifi if you have
                        or doing JTAG and reprogram the MEC with Vertyanov
                          You can try to put another wireless card if thats not help than rewrite Super IO chip.
                            LENOVO t14 pass bios - how can anyone break through mec or through bios?
                              Clear password in MEC EEPROM
                                hi its orignal file no display
                                start laptop 4 to 5 sec sound
                                plz build t14-serial no PF-2A1HZM
                                TYPE NO 20S0-0043UK
                                  hi plzz help me
                                    hi this bios dump no display, pls help. Thinkpad t14 gen 1 serial PF-1B3WRF
                                    Type no 20s0-0032us
                                      Type no 20s0-0032us
                                      Here's your New BIOS, try it and let me know.
                                      all donations are welcome,
                                        thanks for your help but I returned the laptop to the customer.
