here in italy is 65€ship to italy included.. 10€more for some tips and ull done, but this new hot air station looks like to have a pump for hot air, but when it was out my solder was also very cheap and im satisfied with it.
Re: Tool Recommendation: soldering iron and hot air station
What kind of work do you intend on doing with the hot air and how often would you be using it?
IF you are using it for small project or just to learn how to work with SMD (with no real plan on using it for work purposes/daily repairs) then get a cheap Chinese one. They are much cheaper and good enough for above mentioned purpose.
If you however plan to use it to learn and eventually use it 'Professionally'/often, then it's worth the investment in getting something of better quality like the Atten.
Do not skimp on the soldering iron. Good thermal recovery and maintaining temperature when working on different surfaces with varying thermal mass is important. Hot air (contactless soldering as I sometimes call it ) on the other hand is more 'forgiving' as long as the device can maintain good enough temperature at different air flow as well as having a decent amount of air it can push.
If budget is an issue, prioritize on getting a good soldering iron then decide on the hot air.
The iron mentioned is 900 series, not T12. Instead of buying the 2 device, I would chip in another EUR50 for a total of EUR339 (per listing on site) and get the MS300 "All in one" unit which also includes a power supply.
stay away from combined units.
if your in the u.s. then Luis Rossmann has good hot-air stations from Atten that he reviewed on his utube - better than the quick.
i'll post a link later
The MS300 is from Atten and is not an all-in-one/combined unit per se. Its actually 3 separate unit mounted in a frame, of which is the ST-862D hot air station.
today i have discovered also the Bakon 950d that goldenchipset (hklrf) sell for 17.90 dollars plus ship from china. each tip ( t13 format ) is sold for 2.9 dollar
I have a Bakon 950D, less than £20, it comes with a T13 tip but they stick out further than t12 tips, so it's in the recycling and I just use t12 tips.
They don't stick out further, the ridges are in a different place so the element slops about in the handle.
t13 can use t12? and viceversa ? except tips get out much more respect t12, is the bakon any good for the price compared to kesger ?
My first Bakon 950D had a handle for T12 tips and I bought and use t12 tips.
I bought a second Bakon 950D as a spare not realising they came with different handles. The t13 tip that turned up was hard plastic and not comfortable to hold like the original handle.
I bought a handle like the original, there are several different styles available, so ensure the handle is for T12 not T13.
I can't compare to a KSGER but I've been very happy with the Bakon, far better than my old iron where the tips fit over the heating element.
I have watched his videos regarding hot air stations, I absolutely trust his endorsements
