Hi guys
I'm having issues once more. This time with the set mentioned above. There is no display at all but I do have audio.
All fuses have been checked and are showing continuity as good
All Va and Vs voltages have been checked.
I replaced a couple of very unhappy caps on the PS board and the main Y board.
I have removed the Y buffer boards one at a time and no result. Also, when the boards were out, I checked for continuity between the ground connector and all the pins. No continuity showing, so all looks ok there.
Am I looking at a bad panel or is there any other checks I can try? The Z-sus board mentions very high voltages at the connectors but I am getting next to no voltage showing there at all - just a couple of volts.
Any help greatly appreciated!
thanks
greg.
thanks
greg.
