Re: Samsung un60eh6003f horizontal lines
The tabs on the side are "COF" chips. Chip on film. They got the same kind of function as the ones on top.
If the ones on top fail you usually get vertical lines , applying some pressure on the tabs make the lines go away ( temporary ).
When the side tabs fail you get horizontal lines or no picture at all. What you need to do is apply pressure on the side tabs/panel , probably the one on top of the side tabs. Maybe bend the tabs with your finger. The bezel itself probably bends the area of the failed COF.
Dont they get hot? It is something you need to figure out yourself....it is not measurable. If you remove the failed COF chip the picture will be ok and you can do it while the tv is on. It looks like a curtain that opens... very cool to watch
