MSI RX580 Gaming X Plus 8GB Repair Help
    trying to fix a MSI RX580 Gaming X Plus 8GB
    resistances all look normal there are no shorts on any of the rails the card powers on and all voltages are present except v core not sure where to go from here any help would be appreciated
    Its uses GS7256 for memory and memory controller
    https://cdn.badcaps-static.com/pdfs/...3cb0d60647.pdf
    These are the voltages i got from memory
    Pin 1 = 9.2
    Pin 2 = 9.25
    Pin 3 = 1.95
    Pin 4 = 8.84
    Pin 5 = 11.98
    Pin 6 = 0.60
    Pin 7 = 1.24
    Pin 8 = 1.06
    These are the voltages i got from memory controller
    Pin 1 = 10.32
    Pin 2 = 1.33
    Pin 3 = 0.34
    Pin 4 = 9.65
    Pin 5 = 11.92
    Pin 6 = 0.60
    Pin 7 = 1.17
    Pin 8 = 0.76
    Its Dropout Linear Regulator Is GS7166
    These are the voltages i got from it
    Pin 1 = 3.3
    Pin 2 = 3.3
    Pin 3 = 3.3
    Pin 4 = 5.0
    Pin 5 = 0.0
    Pin 6 = 1.8
    Pin 7 = 0.68
    Pin 8 = 0.0
    QM3816N6 Mosfets it uses
    8510
    Multi-Phase Controller It uses is ir35201
    https://cdn.badcaps-static.com/pdfs/...4dea35e76e.pdf
    These are the voltages i got from it, not sure if anything else is needed
    Enable Pin 21 = v3.3
    VRDY2 Pin 4 = v3.3
    VRDY1 Pin 11 = v3.3
    VCC Pin 38 = v3.3
    Re: MSI RX580 Gaming X Plus 8GB Repair Help
    If there is no short on Vcore then you need to check the Power Good signal coming from the Vram VRM Controller. This should generate the Enable signal on the Vcore VRM Controller.
    The P_Good -> Enable signal may go through a few transistors on the way
    If the Vcore VRM Controller IC has:
    Vcc (power to the chip itself)
    PVcc - this should be the 12V rail and may go the the Controller IC, depends which type it is
    EN - enable
    And the high side MOSFET drains have 12V
    And you still have no Vcore...
    Try fitting a new controller IC
    If that does not work then check for other problems (missing/broken resistors or capacitors) around the controller IC
    I hope that helps
    Follow me on YouTube
    Learn Electronics Repair
      thx for the reply
      i fitted a new controller IC and still no vcore
      Enable = Pin 21 - v3.3 is present
      VRDY1 = Pin 11 - v3.3 is present
      VRDY2 = Pin 04 - v3.3 is present
      VCC = Pin 38 - v3.3 is present
      all the high side MOSFET drains have 12V and i couldn't find any obvious broken resistors or bad capacitors around the controller IC there are a few missing things around the controller but they look empty by default
        Have you checked vcc/hvcc/lvcc on the gate drivers?
          all i got was 12v on VCC and 12v on HVCC nothing on LVCC or any other pin
            checked again with some smaller probes vcc/hvcc/lvcc on the gate drivers are all there
              Dunno then I guess you need to study the IR35201 datasheet some more - seems like it is not outputting PWM to the drivers(can you ascertain this?) and you need to find out why.
                theres 8 pins that say pwm on IR35201 i checked there is 1.4v on all of them
                  found a more detailed datasheet for the IR35201 i will study datasheet some more
                  https://pdf1.alldatasheet.com/datash...F/IR35201.html
                    Looks like you need to upload configuration data to the new IR35201 controller, who knew?
                    Interesting video here:
                    https://www.youtube.com/watch?v=tfM9...risFix-Germany
                      thanks for the info that's probably the issue never knew you had to program the new one
                      i put the original one back and did some more measurements since i learned more about how it works and found that its not outputting pwm, but the new one i put on was so looks like it was the vrm controller that was faulty hopefully it will work when the new chip is programed
                        it doesnt say what he used to connect the chip to the pc think this is probably it?
                        https://ie.farnell.com/infineon/usb0...gle/dp/3680237
                          Yeah looks like it, bit expensive tho, especially if it still doesn't work
                            i know, was cheapest i found so far, thought aliexpress would be better but its 137 euro
                              i got the programmer but unfortunately i cant connect to the vrm controller, its too badly damaged to save the config from. i have it set up correct because i can connect to the new chip so unless someone has a config for it, i suppose there is nothing i can do
                                Well, that's bad...
                                There is another broken one on eBay tho
                                https://www.ebay.co.uk/itm/255358620811
                                  If the interface is accessible when card assembled (some boards have pads or even connectors usually at some edge for production process programming), you may buy a new or used card, read out the vrm chip, and give the card back, provided you find a store where you can do this without reason. Maybe not very fair/elegant, but a solution.
                                    theres no connector on it and would have to take the whole thing apart and solder 3 wires to the board. bit frustrating since i think the board will work, just stopped by some software
                                      maybe i can change the settings manually, anyone have any experience programing one of those irIR35201 chips
