Commodore 1084s-p1 fault with video.
    Hi all, i have a 1084s and that was working fine until yesterday. But yesterday monitor is suddenly stopped and faulty now.
    I want simply upload a video about problem, which parts and areas should i check, can anyone help?
    Thanks.
    https://youtu.be/qiizl8iJRLM
    Re: Commodore 1084s-p1 fault with video.
    it looks like a philips chassis, so it could be the line output transformer failed.
      I would first check for a shorted horizontal output transistor or maybe a shorted diode in the power supply secondary. Are you getting any secondary voltages? there is a service manual for this monitor
      Being an old monitor I would I would check the small caps in the primary switching circuit and it could also be a bad cap for one if the secodary voltages. This power supply has a triac for over voltage protection and that "might" be the sound you are hearing
        Yes, it is Philips one. What's the line output transformer, you mean flyback transformer?
          Thanks for advices. I dont measure any voltages yet. Only visually controlled around pcb and dont noticed any bad looking caps or transistors. I have service manual, will check soon. Thanks again.
            yes,
            there is a way to test for this.
            but first:
            remove the flyback transistor and test it.
            while it's out, put a 40w lamp ( a traditional one, not led) across the B+ capacitor
            it should light up.
              yes,
              but first:
              it should light up.
              Okay ill try it thanks
                @stj, I cant spot these points in the pcb, is there any detailed schematics or guide somewhere?
                  manuals
                    thx again, can u give me part numbers in schematics? for example, which one is flyback transistor, 7512?
                    https://imgur.com/a/KKkkpEw
                      Yes, 7512 is the horizontal output (flyback) transistor
                        okay, which one is B+ cap then?
                          2520 10uf - you should see 128v across it.
                            Hello again. I replaced EHT transformer with new one, picture partly came back but another issue appeared now. Here is the video about new situation:
                            https://youtu.be/GIYkvtMsf28
                            Where should i check now? Caps maybe or?
                            Thanks.
                              I just configure brightness potentiometer on the EHT and problem solved.
                                you must adjust focus and brightness on the transformer.
                                brightness is often labeled "screen"
                                you need to do focus first, then brightness, then focus again - because they slightly effect each other.
                                  thanks man, i'll do it again this way.
