asus vivobook max x441sc display problem
    hi guys. i have here a laptop ASUS vivobook max x441sc display problem.
    history: wet unit
    problem: flickering display
    it's like always on sleep mode for sometimes when I press any keys display will show again
    https://www.youtube.com/watch?v=i_hL...ature=youtu.be
    action taken: cleaning
    What could be the problem?
    Anyone have schematics for ASUS x441sc MAIN BOARD REV. 2.1
    Thanks in advance
    Re: asus vivobook max x441sc display problem
    Probably, the LVDS cable is not properly plugged into its connector. is still any corrosion under any IC?
      i cleaned all..no corrosion. lcd connector is properly inserted... i tried to connect vga cable from flatscreen monitor and when the screen flickers, the flatscreen monitor also flickers. That's why im sure the lcd and the lcd connector is ok sir.
      Anyone have schematics for ASUS x441sc MAIN BOARD REV. 2.1?
        Trace the Resistor & Capacitor surround on this Chip may be have Leak?
          I do not have schematics for this mainboard. was the GPU liquid-damaged? was the GPU reflowed or replaced?
            how bout the bios?
