Hello, and Happy New Year to everyone!
In case the thread title isn't explicit enough, here's the rundown:
I've had some self-oscillating Class-D amps on the drawing board for some time now. The designs i've set my mind on, employ IR(S)2110/3 gate-drivers for the output FETs. Now, these chips need an extra 10-15v supply, referenced to the low-side source pin of the FETs.
Linear regulation isn't much of an option at higher voltages, and i've yet to find any IC buck regulators that can take more than 100v input (the final design aims to be a 130v single-supply full-bridge amp).
Sometime, a year or two ago, i googled for discrete buck designs, and the simplest i came across (from among very few) was this design.
Now, i've fiddled around with this design in LTspice, tweaking resistor values and whatnot, and at least for now, i've ended up with what you can see in the attached picture. Output caps will be Chemicon KZE 1200u/16v (i included the ESR in the simulation), and i've just ordered some NEC/Tokin 220u/0.33R inductors. 13.5V output, R5 provides a ~50mA load, and i slapped on that extra LC filter to knock down the ripple. As it stands, it's (supposedly) switching at ~152kHz, and the PFET burns about 3.8W.
If any of you brighter minds might have any tips on how to increase efficiency (even) further, i'd gladly listen Currently, LTspice says that for ~650mW load, it pulls 4.9W from the supply.
