Hi, that card in 3 diferent computers is only detected as a generic display driver, have nothing to do with drivers, post fine but not detected as a gtx, any clue? thanks
GTX 760 not recogniced correctly
Re: GTX 760 not recogniced correctly
Hi, finally it was a memmory fault as ktmmotocross said, thanks a lot.
But the problem was a faulty capacitor near the memmory module that was giving errors, so no need to work on the module, just replace the capacitor
Graphic card working again, thanks a lot
Well, I had a look in the directions where KTMmotocross told me, memmory problem, used MATS, it detected some (14K) faults, had a look with the microscope arround the faulty mem, saw a discolored capacitor and why not meassuring it???, looks like faulty? change it!!!, no heat aplied to the mem chip, so it seems to be just that capacitor out of range, now everything is running fine, detected as it is and GPU-Z tells its fine. Changed pads and thermal paste, runned furmark for an hour and still fine. Card is working and doing what it has to do, play games.
Thanks to KTM user and all of the comunity
