Thermaltake ATX supply goes BANG! - TR2 RX-750
    Re: Thermaltake ATX supply goes BANG! - TR2 RX-750
    Does someone have the technical map of this power supply?
      Is this not a skid mark around this transistor? I do believe whatever this is has puked it's guts.
      Popcorn.
        Originally posted by bcstedt View Post
        Must be the lighting, I don't see any from here.
        No
        You have a lot of bad soldering joints when you see a ring around the joints those need to be reworked
        I would recommend replacing all capacitors that are less than 100uf
        at a minimum
        It would be better if you replace all the caps except the the main capacitor
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          I had to pack up this project due to moving and am now getting back into the stash. I'm doing some more inspection and measurements and will respond shortly.
          Anyone else have experience with this model PSU or similar?
          Thanks for all the suggestions thus far.
            Originally posted by everell View Post
            Measure the voltage across the 400 volt input capacitor. If it measures 166 volts, the APFC (active power factor correction) circuit is not working.
            Input cap voltage is 167V.
              Originally posted by RJARRRPCGP View Post
              I definitely notice a gap in the solder joint right under R7!
              R7 looks okay to me.
              Originally posted by Behemot View Post
              Also check the input cap for bulging, the top is rounded. May be just the plastic but better be sure.
              Just the plastic insulator on top, all the caps look good (not by brand though, obviously).
              I'm going to check the transistors for shorts and see what shows up.
                It's below R7 and to the right of R6.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                16 GB AData XPG Spectrix D41
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  Yeah that's a shadow, little dip in the solder.
                    Found some shorts!
                    Q7, Q8
                    D7, D?
                      Well, I found some of the bang! Looks like R9 spilled it's guts because ... ?
                        ... Q5 and Q6 are shorted. 6R190C6
                          and q5 & 6 are driven by what?
                          that has to be checked next
                            Driven by CM6800G!
                            Any thoughts on replacing the 6r190c6 with 20N60C3 or FCP20N60 (ON Semi) or ... ? I'm searching for details on issues or reliability related to these FETs and found a few situations where these substitutions were made. Also, in one review of this PSU they show the 20N60C3 instead of the 6r190c6.
                            Just curious.
                              Yeah me thinks IPx60R190C6 and 20N60 look like equivalents.
                              Think that 500V FET should be fine as well, it's two-forward when it has CM6800 without even looking, and most of them usually only had 18N50s (or 20N50s when over 600 W). Depends on what you can find around.
