Toshiba password
    Toshiba response code
    Hello i have a Toshiba Tecra S10 i need a response code for :
    PC Serial No. = 3A088517H
    Challenge Code = YGND2-QXBFV-RGT57-FBWV1-PC6DJ
    Response Code =
    Can you give me a response code
    Thanks advance...
      Re: Toshiba password
      Pls send response code....here is image:
      https://imgur.com/a/eCSgrBm
        challenge code = GCGB3-VAMHH-YJM8A-VDEQ4-F9K7T whit sn XE074508H
        can you give me?
        thx
          Response Code = UNK73-J2KHN-HX8D5-8LF97-9KD3Q
            I wasn’t sure if u sent the above response code for me and I’d turned off my laptop for the night, sorry to worry u, here is the new one :
            Serial = 1F031654H
            Challenge code = GJY43-4DD7Q-18MN5-GXL71-FKL4F
            Response code =
              Hey Danito was that response code for u? If it was did it work?
                not working @evserv.
                now challenge code has also changed and the serial number remained the same.
                R7X2D-U3HGE-AFXJM-H2QPB-4T586
                  The serial number always stays the same cause it’s the serial number of the laptop but the challenge code changes every time u turn of the laptop so don’t turn it off. Keep it on charge
                    I’m just putting this here so evserv can see it when he comes online:
                    Serial = 1F031654H
                    Response code =
                      Originally posted by Blayde View Post
                      I'm just putting this here so evserv can see it when he comes online:
                      Serial = 1F031654H
                      Response code =
                      For 1 month it has only been plugged in, it has not been closed
                        What do u mean?
                          Response Code = 5HA4V-9KRKN-F6GQB-TXA8K-0YYJU
                          I give the correct response code, if you make a mistake again, next time there will be no gift
                            Is that for me or danito
                              Pls send mine...thanks in advance ....sorry for worrying u...mine is:
                              Serial = 1F031654H
                              Response code =
                                @evserv
                                Hello?
                                  Do u know his Skype ....on his profile contact info it shows Skype but when I click it it says Skype no longer available
                                  He generously gives away the response codes on badcaps occasionally for free. He does not conduct business here
                                    I don’t want to communicate via any other site. It just sounds fishy and I’m not buying anything cause I don’t have the money (if I did I’d just buy a better laptop) so I’m asking evserv if he could help, I mean he’s helped others, once again thanks I advance and sorry to worry u, here is the response we code:
                                    Serial = 1F031654H
                                    Response code =
                                    Ps: could u pls send the response code within 3 hrs cause it’s night time my side and my dads not gonna allow me to leave a blank screen with random digits on the whole night ( if I turn it off the challenge code will change ). But if u can’t no worries, I’ve noticed that u come online around 9-10 am my side so if I HAVE to turn it off I’ll post the new challenge code early in the morning
                                      I don't want to communicate via any other site. It just sounds fishy and I'm not buying anything cause I don't have the money (if I did I'd just buy a better laptop) so I'm asking evserv if he could help, I mean he's helped others, once again thanks I advance and sorry to worry u, here is the response we code:
                                      Serial = 1F031654H
                                      Response code =
                                      Ps: could u pls send the response code within 3 hrs cause it's night time my side and my dads not gonna allow me to leave a blank screen with random digits on the whole night ( if I turn it off the challenge code will change ). But if u can't no worries, I've noticed that u come online around 9-10 am my side so if I HAVE to turn it off I'll post the new challenge code early in the morning
                                      The time in moscow is 3 hours in front of UK time -
                                      https://www.timeanddate.com/worldclock/russia/moscow
                                        Serial = 1F031654H
                                        Response code =
                                        Finding me on the internet is not a problem...
                                        Write your new code, I will help you!
                                          I managed to leave my laptop on so it’s the same code:
                                          Serial = 1F031654H
                                          Response code =
                                          I really appreciate the help. Thanks in advance
