Re: how to reset lamp hours on acer x117h projector
Resetting the projector lamp timer
1 Open the MAIN MENU. Press ENTER.
2 Scroll down to the MANAGEMENT menu. Press ENTER.
3 Scroll down to the Lamp Hour reset option.
4 Press the right arrow.
The lamp will be reset to zero.
Used to do this at work with Hitachi and Sanyo projectors.
Sometimes the hour counter will shut the lamp down typically after 2000 hours of use or more depending on the age and make of the projector,resetting the counter will eek a bit more use out of the lamp in an emergency.Don't forget to remove and clean both air filters regularly.
Reason: additional info
