24in LG mo PSU/board. Bad caps or Bad board
    The basic caps are all bad but I think the inverter transformer might be bad as well. There is a black burn spot on the other side of the transformer. Though I do know sometimes burn marks can arise just from being hot but ...
    So my question is this. Do you think I could get away with just replacing the capacitors or do you think it would be best just to replace the full board. I found one on ebay for 31$ but its in hong kong and it'll be a couple/few weeks before it gets here.
    Cap it
    0%
    4
    Trash it
    0%
    0
    The poll is expired.
    Re: 24in LG mo PSU/board. Bad caps or Bad board
    Why trash it, its a fairly simple repair ??? the transformer should be fine if you have a DMM you can test it to be 100% sure but its always worth a try.
      ....and the evilbay one from China will have the same crap caps on it you have on the one in this thread. Recap it, quality caps are 1/2 the price of the evilbay board.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
        Thanks guys, I just wasn't sure if getting a new matching transformer was going to be a option or not. I'll post here the results once I re cap it.
          Ok so i recapped the power board and it now comes on.... But now its extremely fuzzy with pixilated lines. Ive tested it on two systems and two power cords with same result. Any thoughts on what else i could do? Also i did update driver and used diagnostic software with no help.
            The picture doesn't look any fuzzier than the bezel in that photo. Are you sure that the resolution is set correctly?
            FYI, It's poor practice to use your email address as your username. It's a great way to attract spam.
              Did you try reseating the LVDS cable to the LCD panel?
                [QUOTE=ajwrighter@gmail.com;584981]The basic caps are all bad but I think the inverter transformer might be bad as well. There is a black burn spot on the other side of the transformer. Though I do know sometimes burn marks can arise just from being hot but ...
                sorry for the late response i was looking at your pictures and when i saw the suscon caps i was like i had to recap my psu in an old emac just because of suscrap (why do companies still use crap caps) i switched all to panasonic FR low-esr series.
                Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
                  i have to ask when recapping one of the boards should you use low ESR caps or general purpose caps also work?
                    low esr.
                    panasonic fm,fr.
                    rubycon zl
                    nichicon hd,ect
                      we
                      I did all the necessary steps before coming here: Checked cables, used different cables, checked software(video card settings), onboard monitor diagnostics, software diagnostics. Then i switched the monitor to a different computer and the fuzzyness still persisted. The lines you see on that picture aren't suppuse to be there.
                        Well FYI, I was unable to locate the option to change it and more than likely my auto fill created it so the damage is done. Also I've never had a problem with spam because that is what filters are for. Besides there are a lot more efficient ways to acquire someones email address
                          I have problem my on Sony TV KDL-47W802
                          from 1 year my picture quality is very and poor video noisy with color not quality as well contrast low, I see HD content like SD , on all source bluray or hd setellite channels or even sample picture on tv not quality
                          are you advise me to replace my main board
