Wifi signal
    Wifi signal
    Hay. Not sure if This post is in the right place but here it is. My neighbor said I can use his wifi. The signal is weak. I assume it's because of the distance. Approximately 150 feet. Also there are other open wifi but are weak also. Is it possible to extend the antenna wire out of the tv to the outside to a antenna to improve signal strength.
    Re: Wifi signal
    get yourself a ubiquiti oudoor AP or similar.
      Re: Wifi signal
      Not looking for gadgets was just wanting to know if its possible. All smart TVs I've been into. Only have a small piece of metal at the end of antenna wire. So could that wire be extended to the outside, maybe connected to an Ariel antenna or simply to so aluminum foil to pick up better. any thoughts will be appreciated.
        Re: Wifi signal
        no, the losses in the cable will remove anything you gain from a decent 8dB+ antenna
          Re: Wifi signal
          antennas on the router might help
            Re: Wifi signal
            Ok. I have routers .Not on his network.
              Re: Wifi signal
              maybe you can use a router in reverse to link to his router.
              some have that option, others can sometimes have better software installed.
              what routers do you have?
                Re: Wifi signal
                Get a cheap tp-link 740, install dd-wrt and connect it to the other wifi network as a client. After that you can use cable to connect your TV ( and other devices ) to that router or add a virtual wireless network to which to connect your devices.
                  Re: Wifi signal
                  +42
                  Relocate the router closest to the neighbor's house. Add a "cantenna" pointed directly at his source. Use CAT5 to make up the distance to the router's previous location. (note "router" can also be a laptop, etc. acting as a bridge)
                  If neighbor really wants to cooperate, he can add a cantenna on his end pointed back to yours.
                  If you can't get close to a mile with such an arrangement, you're not trying hard enough!
                    Re: Wifi signal
                    This is neither smart, nor reliable. If you have money for smart TV, at least buy a cheap router with AP client function, waterproof junction box and put the router on your chimney and then connect it to the TV at your home. Second hand 5210G or M2 costs about 30$. Don't you have 30$ to save from cigarettes and whiskey? Even I have 3 AP's in storage - 2 TPLinks and one Bullet M2. Don't do stupid things if you don't want to be constantly frustrated with dropping connection. I used 5210G to connect to Repotec router on a 1.5km distance without issues. At least 15Mbps at any time.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                      Re: Wifi signal
                      I send you PM message
                      9 PC LCD Monitor
                      6 LCD Flat Screen TV
                      1 Dell Mother Board
                      15 Computer Power Supply
                      All of these had CAPs POOF
                        Re: Wifi signal
                        If youre not looking for a gadget, your best bet is to get your neighbor to reposition his/her router to accomodate you
                          Re: Wifi signal
                          I did more research and found a list of practical solutions that may be of help of to boost wifi signal
                            Re: Wifi signal
                            This was the setup I had when using someone else's wireless network, a D-link AP with detachable antenna arrangement and a small 2.4ghz dish. The AP once configured was sealed up in a box and stuck up the pole with dish, power over Ethernet completed the arrangements. This setup worked flawlessly for a few years until they rolled out ADSL thus rendering the setup redundant.
