Vintage Pace desolder station PPS-100 pump motor bad
    hi
    i jsut got this pace PPS-100 desolder solder station vintage for free
    the motor does not turn when powered on..it just makes some rumbling sounds thats it
    no replacements avail for reasonable price..
    is this fixable or maybe an alternate motor
    here is a pic of stock photo i found online
    Re: Vintage Pace desolder station PPS-100 pump motor bad
    nevermind i fixed the issue..motors works good now
      tell us what you found and fixed lol. The motor capacitor might be low value.
        Sure..there is a plate on back of motor where vsc is...with a thin shim.metal gasket ..i took plate off pkate and motor turned fine by hand so i put plate and shim metal gasket back on ...it then worked...apparently it was bound up against the plate...from years of idled...my neighbor gave me it...its very interesting...even has a rotary tool..)
          I was looking for a replacement pump for the MBT 250, well more specifically the diaphragm overhaul kit, then unable to source that my thoughts turned to a replacement pump / motor assy and found prices for second hand units were not meeting with my approval. In the end was able to source a complete replacement controller at a very cheap price that did meet with my approval lol.
