The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
    Re: The Hall of Shame - Badcaps Photo Montage
    those are from a tyan s2507.
    looks like its never been used.
    customer says it constantly bootloops and bsod's
    several of the brown mystery caps are 10 ohms esr.
      Ok, for my first post here is a shot of 5 popped caps on my Nvidia Geforce 6200 graphics card, kept getting a driver error which I took at first to be a Vista/Nvidia compatability issue.
      There is no manufacturer name on them, they are silver with a blue semi-circle and text on top, FZ72 1000 6.3V. The pressure relief is "K" shaped.
      I take it these are 1000 microfarad..any ideas on the manufacturer?
      Cheers
        these are Sacon FZ series. they have extremely high failure rates.
        Sacon=GSC=Evercon=extreme CRAP!!!
          samxon gd from evga socket 775 dated mid 2007.
          had stability issues.trash on vdimm gave it away.
          several samxon gc on vrm in were open too.
            This is first bad news I've heard for Samxon. The use of GC on the VRM seems odd. Granted, the VRM-out is more critical, but shouldn't low ESR would be used everywhere on the VRM?
              not the first bad news at all.
              gf and gl are known bad too.
                and another samxon death.this time gc
                  hmm 3rd pic went corrupt on the camera.
                  codes are vda
                  105c8
                    These bad Samxon on BBN 680i mobo, right?
                    My SAMXON Capacitors Database HERE!!
                    X-CON is a new brand for SAMXON's Polymer Capacitors.
                      its an evga.rebadged nvidia board.
                      now to figure out whether the caps are a bad batch,junk,or missaplied.
                      i just got 2 more on these with the same caps leaking.
                        Bulging Elite 1000uF 16V cap from a HP 1702 LCD monitor. Feel free to use.
                        Be a mensch
                          samxon gc
                          from an nvidia mobo rebadged evga.
                          less than a year old.
                          some 220@6.3 on vdimm leaking too.
                            I take it that's an Intel Socket 478 Processor not a 775 , with it's 20pin connector.
                            Replace all the capacitors immediately. :
                              Originally posted by kc8adu
                              samxon gc
                              I am surely those are custom made batch for customers(always request by mobo factories), like the case as Intel mobo for Nichicon and Rubycon 820uF 6.3V D8x25mm.
                              Actually 220uF 6.3v have a risk for GC grade by technical problem. I never order those unreasonable stock from factory.
                                lookie what i found in a 1HE (1¾ Inch ; 44,45 mm high .. guess that its called "RU" instead of HE in english (HE = Höhen-Einheit (= Height Unit))) Server PSU.
                                PSU: EMACS MPW-6150F ("Auto Switching")
                                low profile PSU.. running rather hot because the only fan is a hard working (and thus VERY noisy) 40mm one...
                                busted hard..
                                PCE-TUR 10V 3300uF
                                the yellow stuff is just glue... found it everywhere in that psu... looked more like they glued the components in instead of soldering when i first looked at the PSU
                                the tops of those caps are still flat. but all of them had the rubber bungs more or less pushed out..
                                Weird thing is:
                                the only secondary side cap that survived was a freakin Fuhjyyu (on the 12V rail)
                                what the f....?! o.O
                                  Some bloated G-Luxons in an el-cheapo Austin-branded PSU:
                                  (the jamicon is not original, I had already begun re-capping the psu)
                                  Vented Jun Fu caps in an Allied-branded PSU:
                                  For anyone noticing that there is not a single spec of dust in the psu, its because the caps failed from sitting for 4 years! The psu has exactly 0 hours of use, all it ever did was sit in my room. I was not at all pleased with this, as my psu (the Austin above) had just died and this Allied is all I had to replace it with.
                                  Originally posted by Scenic
                                  sry... -.-'
                                  BTW.. my A7N8X came with Rubycon MBZs everywhere.. and with only 1 fan connector above the AGP slot!?
                                  Consider yourself lucky; my rev 1.04 came with the nichicons which I replaced a few weeks ago - they weren't too bad yet. Interestingly, the manual image for my 1.04 clearly shows K vents......
                                  Fortunately my board now matches the manual with it's new MBZ's.
                                    yc(yellow crap?)
                                    in an aspire psu.
                                    could these be worse than fuhjyyu?
                                    note the fuhkyyu were ok while these all hatched.
                                      yc(yellow crap?)
                                      Certainly seems like it!
                                        YC capacitors are common in Aspire power supplies.
                                        Yes, they might be as bad as Fuhjyyu, just not so commonly used.
                                        Mann-Made Global Warming.
                                        - Dr Seuss
                                          Hi all, my graphics card went out on one of my pc's recently. (I had a back up luckily)
                                          Here is a shot of the card below:
                                          I am wondering if I should bother to try and replace them. I guess first step is to find the right replacement. Also, I am wondering whether to replace just the blow caps, or some others too.
