Asus X451c Bios
    Asus X451c Bios
    Hi.
    We need bios for laptop Asus X451CA Rev.2.0
    laptop is working power but no DATA
    Re: Asus X451c Bios
    here
      Re: Asus X451c Bios
        Re: Asus X451c Bios
        добрый день!нужна схема на Asus X451CA.ноутбук не включается после статического электричества , (моргают индикаторы зарядки и запуска ) но не включается.
          Re: Asus X451c Bios
          [QUOTE=grantmaster2;635630]good day!need diagram for Asus X451CA.the laptop does not turn on after static electricity (blink charging indicators and run ) but not included.
            Re: Asus X451c Bios
            I got same problem. After user change ram witout pull out bateri electric static done. When power on no display
              Re: Asus X451c Bios
              bios problems !
                Re: Asus X451c Bios
                Thank you I will try to flash it.
                  Re: Asus X451c Bios
                  also attention , usually this model , fry the second mosfet after dc in , very easy to chek on board if its ok or not !
                    Re: Asus X451c Bios
                    frenz i got heated up on RT8239BZQW in pictures is PU8101. not easy to get replacement this ic. its imposible this ic problem cause by electric static?
                      Re: Asus X451c Bios
                      thank you share !
                        Re: Asus X451c Bios
                        sasser , chek coils for output of that regulator , also chek LDO if present or not .
                        and if it stoped working after ram reaplcement ?? humm have you removed batery before this action ?..does asus and they bios are a pain in the ass ehhe
                        but make sure the regulator got the EN and ldos present , some asus both 3.3 and 5 v are S5 so that mean they will only show up after pressing the on off button :P
                        chek that before and flash EC
                          Re: Asus X451c Bios
                          Is there by any chance you guys have schematic or board view for this model? Thanks
                            Re: Asus X451c Bios
                            thank you
                              Re: Asus X451c Bios
                              Need Help no voltage present to the coil and switch only 1.5v in battery pin is present and 1.5v in one coil need help 3.3v and 5v missing .. Bios problem?
                                Re: Asus X451c Bios
                                Thank Boss
                                  Re: Asus X451c Bios
                                  Thank Boss
                                    Re: Asus X451c Bios
                                    bios above not work for my unit.
                                    do you have bios dump for asus x451ca rev:2.0? thank you
                                      Re: Asus X451c Bios
                                      Post your non working dump here
