acer e5-411 bios
    acer e5-411 bios
    Infos: DA0ZQMMB6E0
    No display problem with this unit...
    Thanks...
    Re: acer e5-411 bios dump needed
    bro try the's http://www.4shared.com/get/dk4oAZWDce/ZQMB.html
      acer e5-411 bios
      Originally posted by Djosla View Post
      first check main power line,than look for 3,3 and 5v, and try to flash bios...
      not sure if it is correct dump but you can try...
      or post old bios dump so we can fix it...
      the file is 4.63 mb........i need a full dump which is 8mb my notebook is facing no display issue
        Re: dead acer e5-411
        thanks for the help, can you please give me the dump for this mobo? thanks
          make backup
          try this
          Im Back... sort of...
            thanks ill try that one, hope it will work
              [QUOTE=ala_borbe;629111]make backup
              try this is a 4mb file and the chip size is 8mb motherboard coad isaozqmmb6ho rev:h
                here is my ori file.the notebook is in no display condition
                  sry i was in a hurry, overlooked size
                  here you go
                    thanks ala-borbe but its still same with your file....but with orignal file it turns on without display......with your file it shows 0.10 amps on power supply but didt turn on
                      this is work dump:
                        Acer aspire e5-411 bios
                        salut tous
                        i need your help for getting a dump of
                        ACER ASPIRE E5-411
                        The mother board is :
                        DAOZQMMB6HO REV: H
                        thanks for any help
                          Re: Acer aspire e5-411 bios
                          Try this:
                            thanks mr on/off
                              not working
                                is archive infect for virus malware
                                  Originally posted by on/off View Post
                                  Try this:
                                  Thanks, It's working. Just need to fix DMI.
                                    Originally posted by nicoleluca300 View Post
                                    not working
                                    Maybe your board isnot bios problem...
                                      Originally posted by polytek View Post
                                      this is work dump:
                                      Hi, thanks for the file. How do you flash it? I've read that you need to put it on a flash drive, formatted as FAT or FAT32. Then, start the laptop with Fn+Esc keys and the flash drive inserted, but doesn't work for me.
                                      Any help is appreciated.
                                      Thanks!
                                        ty ty
