ACER A314-32 bios needed
    I need a working bios on ACER A314-32 DA0Z8GMB8D0 REV MODEL: Z8G please! the problem stuck on acer logo then shuts down and restart. go to bios menu there is no option can enable UEFI AND LEGACY option.I have attached the original corrupted bios, can someone fix this please
    Re: ACER A314-32 bios needed
    try...
      @peste i try your bios but still the same issue acer logo shows up then shuts off and restart, when i go to bios menu still no option to change uefi to legacy
        need help please
          try this one,your win key included.
          W 385000h
            still the same issue secureboot on the bios menu cannot change
              anyone have a working bios on this the problem is turns on boots fine on acer logo then shuts off and restart but when i go to bios menu i cannot change the options on uefi to legacy it just disabled. here it is only showing
                The bios i posted was extracted from acer bios update. There shouldn`t be any problem. Try bios setting with and without the hard drive
                  already tried that without hard drive above picture showing
                    Post your EC backup .
                      If you want to disable SecureBoot you may need to set a supervisor password and reboot. Or just leave it enabled and boot on an official Windows (7, 8 or 10 64-bit) media in UEFI mode.
                        True, on some Acer models including this one if you want to change SecureBoot option, supervisor password must be enabled first.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                          problem solved burning uefi flash drive thanks all for the help
                            EC backup A314-32 password problem
                              W 385000h
                              this works perfect
                              thank you
                                verywell said sir..
                                  Looking for bios bin acer 3 a314-32
                                  Acer aspire 3 a314-32
                                  Model no: N17Q4
                                  Motherboard: DA0Z8GMB8F0 REV: F
                                    Re: Looking for bios bin acer 3 a314-32
                                    try
                                      Did not much id sir.
                                        is it work?
