HP 850 G2 dead no led no fan
    Hy, this laptop no longer gives signs of life, pressing the button does not light the leds or the fan. the jack is intact and there is 19v on the first components.
    A part number HP is SPS 799513-001 it's a Intel I7
    Re: HP 850 G2 dead no led no fan
    you have 3.3v, but 5v..you have voltage on the bios chip .. give more details.
      there is no voltage on the bios chip or spi, on the battery there is 1.2V while on some components there are 1.5v
        when you connect the power adapter do you see light that the battery is charging.. any details how it all began do you own this laptop .. and what are your actions.. do you re seat the ram connect external monitor..before you dismantle it....check for ALW voltage 3.3v 5.0. check the cmos battery if still in 3v range.
        Never stop LEARNING because life never stops TEACHING!
          I don't have the diagrams, the battery is not charged and no LED lights up. every now and then I connect an external video. normal use
            disconnect the battery and try to start the unit using the adapter...check all the coils for voltages.. and post it here...bios ic must have a 3v vcc to function correctly.. check also the rtc bios battery.. disconnect the ram then power on,,
              if you cant see voltage in the coils try to look for short circuit to ground..check the 19 power rail..3.3v alw and 5v alw.. those voltages must be present to power on the unit..
                Check the long part number on the board,if its 6050A2637901-MB-A02 then here`s the schematic
                https://www.badcaps.net/forum/showthread.php?t=85724
                  thanks,,
                    Grazie
                      The plate code is that, there is a short on the L6150 5V coil
                        try to check mosfets connected to this coil..
                          there are inconsistencies between the diagram and the mainboard do not match the components
