Hitachi Power LED flashing
    Re: Hitachi Power LED flashing
    Hello
    MP3398A protection pin find, unfortunately google doesn't tell me much about this MP3398A chip
    many thanks
      The data sheet says operating voltage between 5 to 28 volts, VCC pin = 6 volts, Enable pin =>1.8 volts
      What voltages do you have?
        I can't measure that, I have to turn the power supply, but how? :-)
        I have no problems with LED all are fine
        I have two
        Power supplies bought the same problem
        Find MP3398A protection pin
          If the leds are fine then what is the problem?
            hello i have found something in google with power supply not the place, can you please mark the place for me?
            ISET two resistors 5.09 K ohm and 4.68 K ohm
            Try the 6th leg (ISET) to increase resistance. Instead of 7 kOhm, use 12 kOhm, the current drops and the voltage protection no longer works.
              Remove the resistor 4701 from the red circle and solder it instead for example resistor 103
                many thanks
                  Unfortunately that didn't help me
                    I tested the LED again, they are all fine
                      47 mF 160v
