Please Remove Password In Panasonic CF Bios Dump
    Re: Please Remove Password In Bios Dump
    Originally posted by luvbe3 View Post
    thanks you
    dont forget to confirm...maybe someday, someone will need this file...
    thanks
      thanks
      work fine!. thanks sir!
      how to do this! teaching me!
        you welcome...
        One More File
        thanks you
          One More File
          thanks you
          sorry long time not login... maybe you or someone still need this file...
          goodluck and please confirm
            Hi,rioreno.
            Sorry for the sudden message.
            I'd like to remove the bios password of a CF-AX2.
            Can I remove it?
            thank you.
              Originally posted by Syamu.g View Post
              Hi,rioreno.
              Can I remove it?
              thank you.
              1. Your file is not full bios (bios region only, no meregion etc), use the SPIprogrammer to backup your bios ..
              2. Even though the password is in biosregion and i can remove it, but I'm not sure you can flashing that file without spiprogrammer.
              3. The correct way is to read and write back the file using spiprogrammer...
              4. If you are still curious you can try it without a SPIprogrammer but I am sure you will experience a failure ...
                Hi,rioreno!
                Thank you for answering.
                I'd like to Password remove it by myself.
                Would you tell me how to do?
                  here is the answer Syamu.g.you can use uefitool or HxD.
                    Hi,bachir2004.
                    I have a uefitool and hxd.
                    Then what should I do?
                      Hi,bachir2004.
                      HxD has a "file compare" .Compare 2 files,one with the password ,one without.
                        i miss u so much. it worked thanks you a lot!
                          thanks
                          One More ! please
                            One More ! please
                            this,,,
                            Panasonic CF-NX3EFRCS
                              you may should consider to make a donation to rioreno
                                I think he will refuse it. LOL
                                  And/or to badcaps
                                    this,,,
                                    thanks you. this worked
                                      lol ...
                                        thanks
                                        One More, thanks you
                                          Hi Rioreno,
                                          Sorry to trouble but will I'm trying to read the my "winbond 25Q128FVSQ 1535" bios chip on my CF-SX4, I've clip the reader EZP2019 on to the chip but it detacted the chip as 93_EEPROM instead of SPI_FLASH.
                                          is that correct and if not how can i let it read or detact the chip correctly?
