acer aspire 4752
    acer aspire 4752
    Anyone can help me on this acer aspire 4752 JE40 HR MB 10267-4. the problem is all voltages are present but cannot power on, i notice that if i touch the pin 4
    ON PWRCN1 3.3v bluelight comes if i remove blue light gone, and also notice the mosfet connected to same with pin 4, pin 4 have 3.3v pin3 have 3.3v
    Re: acer aspire 4752
    anyone please help
      bad solder joints may be the cause does the voltage drops #power button ?
        the voltages is not droping it stays on 3.4v but goes up on .42 to up something.I noticed also that when i rest the board for a couple of minutes it can turn on directly with no problem but unplugging and plugging back the charger it cannot turn on but voltages on pin 4 is ok
          try to re solder it...try to test continuity..
          Never stop LEARNING because life never stops TEACHING!
            already did resolder same results I noticed once it cannot turn when you touch the 3pin mosfet 1 and 3 turn on lights blue comes up but when release lights gone
              heat the MB with hot air gun near charging IC & 3&5V regulate & the first 2 fets for any results
                here is the schematics try to trace it..
                  @techtiger i tried your idea reheat the chip and mosfet still the same it turns on when laptop is on rest but after plugging out and plugged in again cannot turn on
                    did you check the ram if its ok... did you reflash the bios? all voltage rails are present? try to reflash the bios chip.. try also to check the rtc bios battery.. is the switch button connected to the keyboard? if so try to disconnect the keyboard and connect the power adapter if it still powers on..
                    here is the bios dump
                    https://www.badcaps.net/forum/attach...4&d=1464192697
                      JE40 HR boardview - https://www.badcaps.net/forum/showthread.php?p=972108
                        @duranitron ram is ok because once it turns on display comes and you can used no problem, once you unplugged the charger and plugged again it cannot turn on, I need to wait for a couple of minutes to turn again, all voltages are present, i did not try to flash the bios
                          tried flashing the bios same result
                            is the fet pu3802 ? when you touch BLUE light comes on
                              @techtiger the mosfet is Q6801 Which touching it bluelight comes but fan is not spinning
                                anyone can help on this please
                                  Remove the ribbon cable from PWRCN1, short pin 3 to GND, see if the board powers up.
                                    @smdflea already tried that nothing happens but if i short this 3pin mosfet blue light comes up fan not spinning but release it blue light gone
                                      Its only for the LED if you think its a problem remove or replace the mosfet. With no power check theres no continuity between PWRCN1 pins 3 and 4.
                                        I tried replacing that mosfet still the same issue
