Neighbor has a constant drain on his car battery...
  • UglyBetty
    • Jan 2022
    • 20
    Re: Neighbor has a constant drain on his car battery...
    Your correct, Acura is Honda....not Toyota. My mistake. Everything else still applies.
    • WebK
      • Dec 2021
      • 9
      • France
      This fuse is for OBD2 Pin16(+batt permanent).
      Try unplug fuse (7,5A), check no voltage on Pin16(OBD2) and resistance to ground.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • gboone
        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
        by gboone
        Hi, I was given this laptop by my uncle who said:
        • It would occasionally shutdown if not plugged in
        • battery had been replaced
        • touchbar would "strobe"
        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
        BUT
        When powered off, it would at some point have a...
        01-27-2025, 09:12 AM
      • mkdj
        ASUS X571 no power : battery issue?
        by mkdj
        Mark and model: ASUS X571
        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
        Tests already made:
        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
        09-14-2023, 11:10 PM
