HP 850 G1 - Unlock Password
    Re: HP 850 G1 - Unlock Password
    Originally posted by AccountSaver View Post
    Hello!
    I have made an original dump with my programmer (which is locked):
    https://we.tl/t-sXObroInlD
    And i have tried with some tools, UEFI Tool,HPUnlocker , etc. etc different tests,but the laptop doesn't even work with those so i am sure i am making some mistakes
    https://we.tl/t-YZiMabJVWz
    So can someone unlock the original dump (it has my win10 key inside and all the info as well) ? Because with the original it works fine.
    Try this unlock or not. Remove cmos or battery also.
      Originally posted by peste View Post
      if it doesn't work try this ..
      You didn't tell me,did you do anything with it? I mean the first one you posted was from Unlocker HP tool ?
      (It was the 1st thing that i did before opening the thread).
      So should i try the newest you have post ?
      Yeah , none battery is attached into the system.
      I will try after @peste.
        We opened and all the , options are NOT grey any more.
        But i have lost everything in Serials etc.
          It automatically did something , first time i see something like that. In restore.
          But we keep missing , serials etc. and Windows key from the embedded chip.
          The good side,is the boot to windows, and that the options are not grey anymore.
            And my file update?
              And my file update?
              Didn't try it. Because i already had results with the file of @peste.
                try the file @imranromi if it is Ok, you will not have to enter the DMI information, if it does not work, write again the bios sent by me and enter the DMI information ... here is the video ..
                https://www.youtube.com/watch?v=9T57ktw8n3Y
                  Re: HP Elitebook 850 G1 Bios Unlock
                  Hi
                  I bought hp 850 G1 in an unknown condition. I checked this model and the problem was a damaged bios, so I bought SOP8 programmer. In next step I desoldered two chips. One is 16 mb and second 2 mb. I cleaned both chips. My motherboard model number is 6050A2559101-MB-A03. I find in internet bios for my motherboard but the bios was to the HP 840 (this is the same motherboard model). So I flashed both chips and solder to the motherboard. Laptop turn on but I was glad too quickly.
                  In this moment i have two problems:
                  1. The following message was displayed: The Embedded Controler MUD data is not valid while MPM is locked. This in not a big problem
                  2. My second problem is more serious. My laptop has two graphic card (Intel and AMD). My operating system sees only Intel card.
                  So I have a question
                  Maby, someone has a bios (i mean 2mb file and 16 mb file) for hp 850 g1 without a password but with support for both graphics cards?
                  Please help.
                    Post your original bios backups, not the random ones you found on the internet .
                      This is imposible. The chip 2 mb and 16 mb bios was in half (i don't know) cleaned/broken. Looks like someone has damaged the bios or interrupted its update.
                      I need any bios with support both graphic card. In the future I will change the motherboard serial numbers if I have the appropriate bios
                        here
                        https://www.badcaps.net/forum/attach...4&d=1553532677
                        https://www.badcaps.net/forum/attach...2&d=1553683272
                          Thanks a lot!
                          I will check in monday and write whats happedn with my laptop.
                          In the meantime, I will be enjoying the weekend
                          BR
                            Hi.
                            After two weeks, I come back with the answer.
                            The Bios works great with my 850 G1 model. I enter serial number, sku, uuid etc with HP BIOSCONFIGUILITY. Everything works great. Thanks a lot!
                            ps
                            I can't edit my last post.
                              bios.bin required for hp elitebook 850 g1
                              hi everyone i have downloaded the correct bios update exe file from hp using the hp detect tool. the laptop has an administrator password on it which i don't have the password. i believe the bios has been attempted to be dumped and written using the hp unlock exe tool but the bios chip has been dumped with a bad dump and unfortunately has been erased and written with a bad unlocked.bin and now does not have a good backup of the original bios.bin
                              ch341a was used with a poor clip attached. I have now removed the bios chip. is it possible if I upload the manufacturer bios setup.exe file someone could make me bios.bin from it so I could erase the chip and then flash back the proper bios.bin that someone would be kind enough to make as I have no experience in creating or extracting a bin file from an exe file. if someone can help me out would be very much appreciated.
                                Re: bios.bin required for hp elitebook 850 g1
                                post the name of the motherboard model..and the backup of the bios as corrupt as it is ..
                                  Re: Elitebook 850 G1 please for help unlocking password
                                  How do you create a dump file of bios
                                    you need an SPI programmer
                                    https://www.youtube.com/watch?v=DWWigscuQDY
                                      Hello
                                      Can someone help with a bios reset on the Elitebook 850-g1?
                                      Thanks in advance
                                        Originally posted by girolamo View Post
                                        Hello
                                        Thanks in advance
                                        Did you try RCUnlocker
                                        https://www.badcaps.net/forum/showthread.php?t=98539
                                          Yes, i downloaded it, and successfully reset the bios!
                                          Thank you
