asus x550VB keeps on sleeping mode
    Ive already disabled all sleep option on the laptop but sometimes it goes sleep
    Those the memory could be the problem?
    Re: asus x550VB keeps on sleeping mode
    Does it sleep after 30 minutes or at different times.
      sometimes a 1min somethimes 30 min and sometimes after starting
        Does it go into sleep or does it shut off completely ?
        If it goes to sleep I highly suspect there is something wrong with the lid switch.
          Yes it shut off the you need to press the power to see its display again
          I also think its the LID switch because if I jsut remove the power flex it will not sleep
            It would be important to know if the laptop does indeed shut off completely or go into hibernation/sleep.
            The power led does usually "breathe" or blink when the laptop is hibernating or sleeping.
            Plug the power flex back in and wiggle it a little while the laptop is on. You might also try flexing the boards a little. Maybe there's a broken solder joint somewhere. But don't bend the boards like crazy! That would cause more damage.
              Thanks I think the problem was the TRANSISTOR around the powerbutton board i think its faulty
                Yes, that is the lid switch.
                  [IMG][/IMG]
                  what type of trasnsitor to
                    Its a hall switch as rhetoricalcheese said. Get one from a donor ,any 3V one will do.
                    It might be this AH180N-WG-7 https://cdn.badcaps-static.com/pdfs/...d4bcdd1b93.pdf
                      [QUOTE=SMDFlea;927388]Its a hall switch as rhetoricalcheese said. Get one from a donor ,any 3V one will do.
                      It might be this AH180N-WG-7 https://cdn.badcaps-static.com/pdfs/...d4bcdd1b93.pdf[/QUOTE
                      can u give me some quivalenvalue sir
