Needed Bios Dell Precision 5530 password
This topic is closed.
    need good clean unlocked bios please. thanks!
    Re: Needed Bios Dell Precision 5330 LA-G341P Rev1.0
    Do you mean the 5530 ,post your bios backup .Whats the service tag number .
      ah yes sorry 5530 heres my backup and service number is HL56HR2
      update: realized there are 2 windbond chips on this machine i uploaded the second dump as well.
        Both files aren`t proper backups,or both seriously corrupt. Are you using a sop8 clip ,and a ch341a ?
          no im desoldering the chip and soldering it directly to the clip adapter which has solder pads for chips. using a TL866II Plus havent had problems at all. unless those chips arent bios related..
          ah ok so i found another chip which is most likely the bios its a Gigadevice chip. ill dump and upload
            here is the 3rd and im sure correct dump.
              got a hold of this bios file which worked.
                Dell precision 5530 password unlock
                Hello! Can some one please help me remove bios password .
                Thanks!
                  Re: Dell precision 5530 password unlock
                  EDIT : it's looks like it was power on password.
                  Any one that's want to check and clean bios file.
                  Thanks!
                    1) please send board pic with part number mentioned
                    2) cpu details with sr number
                    3) laptop model details with service tag
                    4) send all these mentioned above and i will try to make fresh bios for you!!!
                      Thanks!
                      try...
                        Originally posted by rioreno View Post
                        try...
                        Thanks for the help! the bin worked i think? but it did not solve my problem still stuck at dell security manager screen .. is it possible to remove boot password? thanks!
                          Dell precision 5530 password unlock E7AB
                          hi, some one help me clear this password please!!!
                            Re: Dell precision 5530 password unlock E7AB
                            help...
                              Precision 5530 bios password
                              Hello everyone, I would like to remove the password on a precision 5530 it would be appreciated
                              i send my .bin file
                              thanks all
                                Re: Precision 5530 bios password
                                i send my .bin file
                                thanks all
                                try..
                                  Working great !! Thanks you Peste you are the best !
                                    I think you may very well be out of luck. I have a similar code, and I think it's virtually impossible to unlock be bios for a computer ending in E7A8. I'd love for someone to prove me wrong.
                                      Try this website, and let me know if it works. ****************om
                                        Laptop is still under warranty, you may try to register it under your name at www.dell.com, wait a few days and then contact Dell support through chat to obtain the master password, you may have to do a "blind ownership transfer" if you don't know the name of original owner. This have worked for me with a couple of Dell XFR laptops that were sold in the United States, laptops that I had purchased through eBay and were still under warranty; unfortunately the laptop you have was sold in Vietnam and Dell master password policies may be different... but it's worth a try.
