HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
    Please help me.
    Not boot removable device, or hdd or ssd. Bios info or boot menu see device
    Not boot all device.What problem Bios?
    Re: HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
    bios version is Q85_010901 Rev.A.try this and report back.
      First boot working alles ok. Secund boot not boot alles restart.
        Do you have your original bios backup .
          No backup BIOS, unfortunately this is how it got to me
            Try this bios .
            Intel Management Engine (Consumer) v11.8.70.3626
              Try this bios .
              Thank you very much
              Working
                would it work if I was to flash the same model with this bin ?or do i need to submit my own dump ?
                  you can try, but before you make a copy, if nothing goes, put the bios backup here and someone will help you.
                    Thank you, so far i'm still trying to read the chip and i'm helpless so far so i'll get back on the forum when i manage that
                      HP Probook 470 G5 BIOS request(repair or known good)
                      Hey guys, grateful if someone can check if the attached BIOS is not corrupted and/or provide a known good BIOS please.
                      Issue:
                      Laptop came in as not turning ON. I did a BIOS reset and laptop now has power but not booting.
                      When power adapter is connected, power key light comes on, goes off then comes on again. When it comes on again, there is 5 long blink on caps lock and numlock simultaneously. Once the 5 blinks stops, fan ramps up to full speed and stays there until device is forced off. No display and HDD does not spin.
                      What I tried so far:
                      1. Clean ME of original BIOS dump
                      2. Change ME version form 11.8.55.3510 to 11.8.70.3626 (consumer)
                      3. Tried BIOS from this thread: https://www.badcaps.net/forum/showthread.php?t=82574
                      Motherboard: X8C DA0X8CMB6E0 REV:E
                      There were some dead ants when I removed the black sticker but aside from a slightly corroded resistor near Touch Pad connector (already fixed) motherboard is spotless.
                      All voltage rails except CPU Vcore and GPU are present and stable. BIOS resistors are OK and data activity can be observed on DSO when powered ON.
                      Grateful for any help. Thank you!
                        Re: HP Probook 470 G5 BIOS request(repair or known good)
                        Bump. Anyone?
                          Hello
                          try this and reply me
                            Thank you @mrwab but not working unfortunately. Still same issue.
                              Bump, anyone please?
                                try
                                  No luck, still same.
                                    Hp Probook 470 G5 -Bios needed
                                    hi friends
                                    i need for this model bios
                                    hp 470 G5
                                    DA0X8CMB6E0 REV:E
                                    THANKS IN ADVANCE
                                      hp 470 g5 -repair bios files needed
                                      need repair this corrupted bios files
                                        Re: hp 470 g5 -repair bios files needed
                                        try..
