Daewoo microwave oven repair
    One day my microwave oven stopped heating.
    It would turn on and rotate the plate but no heat.
    I removed the cover and checked components with digital multimeter.
    Found that the high voltage fuse was blown.
    This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
    Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
    I replaced fuse and tried to heat up a glass of water.
    Strange noise was coming from the oven when it gave power to the magnetron, but the familiar noise of the magnetron generating the heating waves was not heard and the water not heated. Instead, I could smell some burnt electronics/plastic smell coming from inside the enclosure so I turned it off quickly and checked again.
    The fuse, being of bigger current size, doesn't burn any more but something has definitely failed inside the oven.
    Then googled "microwave oven works but no heating" and stumbled upon this video:
    https://www.youtube.com/watch?v=9BUalRbhWG4
    Turns out that on the magnetron connectors (that contain some capacitors inside), one of the connector is arcing to the case of the magnetron.
    So, I ordered connector and HV diode from aliexpress/ebay. HV diode looked discolored from heat but was not able to test it with digital multi-meter (appeared open, DMs cannot test HV diode except if it's shorted). I thought it would be a good idea to replace it anyway.
    So, I replaced the connector and diode and the oven now works as new!
    One think I did different from the repair in the video linked above, I did not use screw terminal for the new connector terminals, I just soldered them to the magnetron as you can see in the pictures uploaded. The original terminals were welded. I hope it lasts.
    Re: Daewoo microwave oven repair
    One comment I have for you is as follows
    I would have wrapped the wire around the terminal and then soldered it so you would have a solid mechanical joint plus a solid soldering joint as well
    Because what you might notice is a few months from now that the stress from heating and cooling of the heater element might cause it to crack [ soldering joint ] and cause connection issues ( also vibrating of the magnetron might also cause the same problem )
    I have work on some microwave ovens in the past and never seen this type of failure before
    On this note where did you find this connector that you replaced could please post the website link to it
    Thank you for posting your finding in this forum
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Nice work getting it fixed!
      I also like that this is the older type microwave oven with line-connected transformer and cap instead of the newer "inverter" technology ones that are constantly popping here on my local Craigslist for free due to going bad more frequently.
        Well, I should have thought this earlier, now time will tell how long it lasts..
        I bought the HV diode I replaced from here:
        https://www.ebay.com/itm/5pcs-HVR-1X...72.m2749.l2649
        Here is a link to the connector:
        https://www.ebay.com/itm/5Pcs-Electr...72.m2749.l2649
        Quality seemed to be OK but they had some visual differences (it's 5 pcs lot), they were not identical.
        You can also buy the connector with screws and nuts as a kit ready to replace the shorted one from here:
        https://www.aliexpress.com/item/4000...775b6555vbJAfM
          I have only heard of those inverter microwave ovens but I haven't seen one. I suppose they would be expensive, compared to the old ones. And you telling that they fail more frequently gives me another reason to not like them
            invertor microwaves are probably cheaper to make thanks to the filth on the metals-exchange pushing the price of copper through the roof!
              Where are the diodes in your repair? I cannot see anything in the picture matching the ebay link you shared
                Well, the problem with inverter ones is that any simple issue on HV/magnetron will usually destroy the inverter MOSFET/IGBT, HV diodes, and sometimes driving circuitry too. So it can get complicated (and often not worthwhile) to repair.
                See, on yours, it was just a bad connection which blew out your HV fuse and HV diode. You replaced the fuse, but not the diode and didn't fix the connection at first. And with that, all you got was bad buzzing, but nothing sustained any major damage. So you fixed the bad connection and HV diode, and everything worked fine after that.
                Now if this was an inverter MW, the inverter MOSFET/IGBT would have probably failed too, along with a bunch of other stuff. Basically, these inverter microwaves are similar to the inverters in LCD monitors... just made for higher voltage and much higher power output... and don't usually shut down gracefully like LCD inverters do when there is a problem. Instead, electronic parts often get sent to orbits until a fuse somewhere finally opens. In short, everything works nicely until one part fails. After that, it can all go haywire very quickly.
                If you haven't seen one inside, here is one I parted out a long time ago:
                https://www.badcaps.net/forum/showpo...&postcount=250
                https://www.badcaps.net/forum/showpo...60&postcount=8
                ^ Basically, it was badly rusted and not worth the effort to repair. So I sent the parts to someone who needed them to fix another MW and scrapped the metal bits.
                On that note, those "stainless steel" appliances aren't so stainless steel inside.
                Exactly.
                The inverter transformer is tiny compared to those line-connected ones. Also don't need a huge cap and can instead get away with much smaller PP / film caps, due to higher frequency. So those inverter micros are cheaper to make.
                  https://www.badcaps.net/forum/attach...6&d=1363046489
                  Is that all of what in this type of microwave oven really
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    ^ Yup, that's it.
                    You get a line bridge rectifier in the top left of that heatsink, a few polypropylene caps (I think one is for filtering the rectified line from the bridge, while the others are for the inverter HV section), and an IGBT or MOSFET (also mounted on the heatsink). Then there's the transformer, which is pretty small compared to the old chunky ones, and the HV diode connected on it. But that's all there is to it, really.
                      I haven't yet seen a microwave oven with rusty cabinet. This is Panasonic not some cheap Bulgarian brand such as Arielli which is very popular here in Greece for the very low prices of its product line.
                      I don't know where this was stored, but the inside of the cooking chamber shouldn't rust like this. The oven doesn't look too old too to justify this level of oxidation.
                        BTW the oven still working and warming my food every day
                        here:
                        https://www.badcaps.net/forum/attach...9&d=1611525320
                        https://www.badcaps.net/forum/attach...0&d=1611525320
                        on the bottom right, near the large AC capacitor
                          They used to sell special microwave paint for touch bad spots for inside the microwave shell
                          But I have not seen any for a very long time
                          9 PC LCD Monitor
                          1 Dell Mother Board
                            Considering that it costs $12 to mail something to my parents if it's 2 pounds and $18 if it got to $3, shipping heavy copper + laminated iron MOTs is part of the overall cost that shift towards transistors and flyback transformers...
                            Speaking of microwave troubles, my 1.5KW oven had bad caps that ended up destroying a relay. I jury rigged another open frame relay to replace it as I didn't have a sealed one in my junk pine, I'd expect it to fail due to environmental issues (cooking vapors) but so far it's still working, and I still haven't ordered that "correct" relay.
                            And my parents already threw out two microwave ovens due to rust...
                              I found a Panasonic inverter microwave oven in the trash, took it apart and yes it's very light no heavy transformer. Instead it's all electronics, IC's IGBT. It' s battle of high tech that china, korea can not come up with or understand, and good old heavy low tech.
                              My microwave oven is dying, I can see the light bulb flicker bright/dim constantly so something is cutting out intermittently. I tried putting it on a power meter but it averages the readings and next I should try a fast ammeter.
                              Never seen rust in ovens, but habit is to leave the door open after cooking to air it out.
                                Anyone bodge fix microwave oven diode failures with a pile of 1N4007's?
                                  I think they are too slow switching, I know 1N5408's are worse and blow up in series, when I used three at 2kV.
                                  Even though it's a 50/60Hz sine-wave, the dV/dt is very fast and it takes over 5usec for the diode to turn off, and by then they aren't splitting the voltage across them equally and poof. Maybe if you used a bunch of matched parts it might work. Fast-recovery is needed I think.
                                  A CL04-12 is 12kV at 450mA and around 13 diodes in the string for American Semiconductor, vs 10 at hung lo. But no switching (off) time spec given.
                                    that gets me thinking, i wonder if a microwave oven diode or maybe 2 in series can be used to repair old crt monitors or scopes with the diode in the anode cable.
                                    those old fuse-shaped diodes are almost impossible to find now.
                                      put a couple of turns of wire around the live wire and hook your scope-probe to it.
                                      you should get inductivly coupled current on the screen.
                                        The question is if microwave oven diodes are slow or fast recovery. They seem to all be fast-recovery, inverter use etc.
                                        For the old B&W TV's and monitors, those HV rectifiers in a cartridge (really old are selenium stacks) I use a smaller fast-recovery diode like 2CL69 5mA 4-20kV but the 10-20kV parts 2CL77 need to be potted or it arcs across. If making a scope HV multiplier.
                                        Microwave oven diode would likely work fine.
