Thank you to the guys at HEGE supporting Badcaps HEGE HEGE DEX Chart
Post your worthless and/or pointless repairs
This is a sticky topic.
    Re: Post your worthless and/or pointless repairs
    Oh yea I do this crap when I do not have the right part sometimes double up capacitors back to back lay them down just to make it fit in the case sometimes it works sometimes it does not
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Originally posted by sam_sam_sam View Post
      No there is nothing wrong with you ——> it's manufacturer that use shit-e components that there is something wrong with them they are greedy and only interested in making as money as possible and giving the customer crap
      I would recommend that when you recap something use well known capacitor brand manufacturers not some more of the same exact crap with different brands names
      I meant why am I bothering to fix my ancient, decrepit PC instead of just assembling the parts I have sitting in boxes 10 feet away and have a way better PC?
        I tried to fit a different speaker in those computer speakers that smoked a long time ago. The sound quality isn't worth the parts cost (Peerless TC6FC02-04 drivers, on sale at Parts Express for $9.80 each) and the time it took for me to cut those adapters. They sound about the same as the original drivers, but with less bass. However, I haven't changed the driver in the left speaker yet, and the amplifier has a problem with weak bass in one channel that I never figured out.
          ^ Nice!
          So wait, you bought those drivers specifically to fix these speakers? At almost $10 a piece, I can get a 2.1 system in good working condition around here. But I guess that was the point of your repair/exercise, wasn't it. Fits the thread pretty well.
          As for the weak bass... I imagine that is likely caused by a bad cap somewhere - either electrically leaky or high ESR / low capacitance. If you swap the input signals going to each pin on the amplifier IC and the weak bass follows, the issue is before the amp in the signal circuit somewhere. And if the issue doesn't follow, then either bad output coupling or feedback cap in the channel with the weak bass. And if it's neither of those, perhaps the amp is bad. In that case, crank it up to the max and let it smoke itself out?? Bonus points if you use an adapter with voltage rated very close to the absolute maximum rated.
          Anyways, that modded/repaired speaker looks totally badass like that. Love it!
          Unfortunately, I'm too cheap to spend any money when it comes to stuff like that... but NOT time. I posted this repair on a pair of cheap Acousitc Audio speakers a while back... and looking at it again, I certainly should have put it here in the worthless repairs thread.
          So perhaps if you want to waste even more time with these speakers, you can try to rewind the old smoked drivers, if you still have them.
          As for my more recent worthless speaker repairs... I did two speaker surround jobs: one on a single Boston HD8 speaker, and another on a pair of old and kinda crappy Philips speakers. Both of these were too cheap to waste money on surrounds... so I did them the same way I did my good ol' Realistic Nova-18 speakers: made the surround myself from paper. Though on that note, I should say I've improved the "quality" of my surrounds quite a bit. Seems that paper towel and latex house paint make for a decent surround material. Perhaps I should post pictures of these two with some details how to make them. The Nova-18 speakers were my first try... and they still work! I actually listen to / abuse those speakers quite often. They don't sound good, but there is something about their heavy speaker cones that produces a strong vibration in the chest and makes them sound 10x louder than they are. And being mid-range "bright", they actually sounds OK for everyday listening. Also, after all these years of me occasionally abusing them (cranking the volume to silly levels where the speakers distort... but still don't burn out for some reason), the paper surrounds have finally broken in to the point where they don't make any noise with high cone excursion (>5 mm each way). This is where the paper towel + latex paint helps on my "improved" versions, as that material doesn't need breaking in to get rid of surround noise. It's still an extremely lo-fi repair, though.
            Nice... I tend to bin small speaker enclosures with bad drivers, though I have repaired one speaker with bad tinsel wire... fixed with homemade tinsel wire...
              I kind of did, but they can be reused for other projects. I'm curious to see if I can make small speakers that don't completely suck. Some companies have tried, but they just boost the "midbass" range into distortion (which most 2.1 computer speakers and all mini-stereo systems also do). Where I live, the only way to get computer speakers for $20 is to buy new, and everything in that price range is the kind of stuff that has fake reviews on online stores.
              From what I remember, changing the input caps affected which channel had weaker bass, but the actual cap value didn't matter. It also doesn't affect headphones, which is strange. The headphone jack is connected to the main amp output with ridiculous 390 ohm series resistors. Maybe I need to get some more 100uF caps to see what happens if I swap the caps around the TEA2025B.
              I thought about it.
                Amplifier in those speakers a single ended (with dc blocking capacitor), bridge, or bipolar driver? Highly doubting bipolar but bridge is possible, else cheaper single ended...
                Suspecting the bipolar and bridge configurations have better bass response that won't get eaten by the blocking capacitor?
                  It's single-ended.
                  Other configurations might still have a DC blocking cap on the input.
                  To make this even more pointless, I have some sound damping foam that I could stick on the inside.
                    Good point!
                    Heck, making your own enclosures might give better results than the original plastic ones. Actually, weren't you the one that did that before? I remember a picture on BCN from quite a few years back with some home-made enclosures. I think it was yours, but don't remember 100%. Looked pretty cool, though.
                    Probably.
                    I have a pair of slightly more "premium" stereo computer speakers from the late 90's, and they aren't too bad at all. They use 3.5" (or is it rounded to 4"??) "woofer" drivers going full-range, and a smaller set of 1" drivers for the tweeters. Branded "Saturn", model: SP-632A (and look similar to SP-622/SP-610/SP-5100/SP-500 series if anyone cares to look those up.) Based on a KIA6283k single-ended amp IC. They sound very decent, especially for close proximity listening, like they were intended for. Obviously not going to shake any walls with bass, but go down to 50-60 Hz range with relative ease and flatness in a small room. Some of the late Sony CRT TVs used very similar drivers, and they pumped out pretty good sound. Magnetically shielded too, so my CRTs approve!
                    Yeah, that is true.
                    A lot of the cheaper 2.1 systems have a dual-chamber woofer built with one chamber sealed and the other one ported. The "woofer" driver (typically 3.5-4" cone size) is positioned on the wall between these. Given the small cabinet sizes of these woofers, they have the typical double-humped response, with one peak in the 40-55 Hz range, and the other in the 100-120 Hz range. Their bass response also drops off very sharply below 40-50 Hz, depending on design.
                    So yeah, they do often have a boomy midbass, or at least very exaggerated low-end on voice content. Even then, though, these are still a lot more controlled than on cheap old ported speakers from the 90's.
                    The Realistic Nova-18's mentioned above are actually a prime example of that: they easily go +20dB (or at least sound like it) in the 70-80 Hz range, but drop off quickly below that. "One-note wonders", as some people call them. Of course, that's what happens when you couple a heavy, thick, paper cone with a 1" voice coil and a very weak motor (small magnet + large magnet gap): motor can't control the cone, and the cone does whatever it wants pretty much. Couple that with cheap shallow cabinets (check ), and it's an audio disaster... or a success, if you're trying to annoy your neighbors. Nothing like a thumpy bass going through multiple walls. Almost like taking a hammer and hitting on the walls.
                    I guess that's something I didn't consider. I live in a fairly populous suburban area surrounded by other similarly-sized suburban areas... so probably that's why. There's also always a lot of people moving in and out of this area, too (read: fairly good amount of yard sales and curb alerts when these people move.)
                    Well, the headphones wouldn't be affected, because they have a large impedance (typically 32 Ohms for most cans), in addition to those silly 390-Ohm series resistors. So even if one of the output coupling caps has gone down to 100 uF capacitance, you still won't notice it with headphones, because that sets the -3 dB low-pass cut-off point at about 4 Hz with those series resistors. But without those resistors and with an 8-Ohm or 4-Ohm load, the -3dB goes up to ~42 Hz or ~85 Hz, respectively for 470 uF output coupling caps (or ~20 Hz and ~40 Hz for 1000 uF caps, respectively.)
                    So if the output caps are bad (low capacitance and/or high ESR), that can really affect the -3dB cutoff frequency.
                    You can use this tool to see how the capacitance affects the -3dB low frequency cutoff for amps with DC blocking / AC coupling caps on the output:
                    http://sim.okawa-denshi.jp/en/CRlowkeisan.htm
                    That too.
                    I thought about it.
                    You should.
                    Provided you can find thin enameled wire easily.
                    I suppose if you don't mind sacrificing a small DC motor, you can probably get some from there... or scrapped CRT TVs possibly (yoke and focus/pin coils.)
                    If the speakers are stereo and there is only one TEA2025 amp IC, it's a pretty sure bet it's going to be single-ended application (with DC blocking output caps.)
                    Yes... though if the output DC blocking / AC coupling caps are large enough, you will still get very good bass response.
                    As shown with the RC low-pass filter calculator tool above, 8-Ohm load with 1000 uF output cap sets the -3dB at about 20 Hz... which is pretty acceptable. Most of the time, the drivers and the enclosure will be the limitation with such small speaker setup, rather than the output caps... especially on tiny speaker drivers that really can't go down below 50-60 Hz anyways. Might as well block those lower frequencies from going into the driver and wasting power unnecessarily... which could matter in a positive way if the power supply is undersized, as is typically the case with very cheap desktop speakers.
                    LOLz.
                    Actually, the most that will happen from doing this is you might dampen some cabinet resonance/vibration, especially if the enclosures are rattly and cheap. If it's a ported design, though, generally damping will make you loose a few dB (at least with larger speakers... not sure if there would be a difference with small desktop speakers like this.)
                      Good point!
                      That was me.
                      The original drivers in these speakers were about that size (92mm outer frame diameter). I was thinking about something that would beat those really expensive Bose computer speakers. There are some Tang Band speaker modules that might do it, but I don't feel like paying that much (close to $70 for a pair).
                      The really cheap ones have a simple ported enclosure with what looks like a toilet paper tube as a port. One example that I have personally listened to is the Cyber Acoustics CA-3602. On those, turning up the bass control just makes speech impossible to understand, and the bass response drops off at about the same frequency range as the old Dell / Harman Kardon 2.0 speakers like the HK-206.
                      You should.
                      I didn't spend much time looking for wire, but I don't think I have anything in my scrap pile with thin enough wire.
                      LOLz.
                      These are cheap, but resonance is less of a problem with the new drivers. Putting damping material in modern $10 speakers would be even more pointless, although the set I have sounds better with the speakers in free air than with the speakers inside the enclosure.
                        I made my speakers more pointless with a notch filter to get rid of the big hump in the midrange response (I have to use a third-party website because the Peerless datasheets are broken). That 2kHz peak was annoying and caused that "tinny" sound. I haven't trimmed the leads yet because I don't know if I have the correct resistor value yet.
                        I don't think these drivers are really worth the money once you add in the price of the filter components. There are even other Peerless 2" drivers with flatter frequency response, like the TC6FC00-04 (although the off-axis response looks worse). At least the magnet structure they use has a weak external magnetic field, so they can be used around CRTs.
                        Also, you can see that I still have a 512MB flash drive and my really fast Transcend drive is at the bottom of the pile.
                          LOL! But also really cool to see such a tiny speaker used in place of a full-range speaker.
                          Yeah, I think the sound would still be "tiny" no matter how many notch filters you have or how big they are. The speaker itself is rated from 150 Hz and up, with a self-resonant frequency around 170 Hz. So it's really more of a mid-range / tweeter driver... and 2" diameter is right for that anyways. Actually, I'm quite surprised that such a small driver can go so "low" in the frequency response.
                          Your notch filter really inspires me to try and do the same to a pair of headphones I found recently for free (they came in a small PC PSU parts lot.) For the most part, I can correct a good deal of their frequency response with an EQ in WinAmp. But TBH, I never really liked how software EQs sounded in Windows (especially when pushed really hard to correct a lot.) So I'm curious to see if a hardware notch filter / band-gap filter could do them better justice or not. They have really really strong bass, which I'm OK with. But the mid-range is even stronger - in fact, so strong that it took me to a while to figure out what exactly needed correcting, since they sounded like listening through tin cans under water - literally! I'm not exaggerating a single bit. After severely attenuating the low-mids and mid-mids, then boosting the low-highs, mid-highs, and high-highs... they sounded... acceptable. It's the strong bass that I like about them. However, the #1 thing that I absolutely hate about those headphones is how tight they are on my head, and I don't have a big head. They are over-the-ear design, so after about 1 hour, my ears felt completely numb. I remember playing around with some woodworking clamps in my uncles workshop when I was a kid - particularly, how I thought it was funny to tighten them around my head (and maybe that explains my loony behaviors at times ). These headphones simply reminded me of that with how tight they were. Ugh!
                          While on the discussion of speakers/audio... here are two pretty worthless speaker repairs I did (one last summer, and one last spring):
                          Boston Acoustics HD8
                          https://www.badcaps.net/forum/showthread.php?t=103073
                          Philips F9217L-50R
                          https://www.badcaps.net/forum/showthread.php?t=103598
                          These involved replacing rotten foam surrounds on the woofer drivers with home-made / DIY surrounds from paper towel and latex/household paint. Pretty ugly ... but it works, for what they're worth.
                          Hey, I'm still using my Sandisk Cruizer "Mini" 512 MB stick here too. Those old flash drivers are actually quite reliable. In my case, I use mine as a temporary backup of Word files and other important documents - at least until I get files synced across other computers too. I've had that flash drive since high school. I remember my mother bringing it back from work one day and asking me if I needed a flash drive - I did! Back then, I had signed up for a computer graphics (early days before it eventually got renamed to "graphic design") and didn't really have many choices to store my files for later viewing/work at home. Back then (mid 2000's), floppies were out of the questions (especially for Photoshop files), but we often still burned CDs as a way of saving and moving around files. When the first flash drives came out, it was a revelation of how quick and easy it was to move files. So I've been using my 512 MB Sandisk since back then and never really stopped using it. I think I've re-written it with data more than several times over now... and yet also still have a few files from back then that are still readable.
                            I get a little bass from it, but I think there's a dip in the response just above the port tuning frequency. I think there's still a little peak around 1kHz with the current component values (47uF cap and 130µH inductor - it ended up working the best without the resistor), and I hear a second hump that I can remove by dropping the 250Hz and 500Hz sliders in a software EQ.
                            I first thought about doing that around 11 or 12 years ago when Parts Express had a really impressive-looking unbranded 2" driver that they were dumping cheap ($2, if I remember right). I ended up only getting one of those drivers and using it for testing (building something like the old Radio Shack speaker with the built-in amp), and I noticed the foam surround starting to degrade a few months ago. Recently, I saw some speakers from Tang Band that have a 1" driver and a passive radiator in a tiny enclosure, and now I'm thinking about a passive radiator design. I also saw the Tectonic BMR drivers (and I think there was another brand that made a similar driver) that are supposed to have really good off-axis response...
                            Now I'm thinking of the physics professor I had in college who said that a 15" subwoofer was small.
                            I never liked the way software EQs sounded either. Boosting a frequency range is worse because it can start clipping.
                            My current headphones felt tight for a while, but either I got used to it or they loosened up. They're also the over-ear type (Samson SR850).
                            I got this one when I was in middle school. I haven't used it in a few years, but I used it pretty heavily in school (all the way through college). It's also one of the fastest USB 2.0 flash drives I've seen. I saw more Zip drives than CD burners back then, but those were annoying because no local stores sold anything other than 100MB disks. There were some places that had Zip 750 drives, which could only write to 250MB and 750MB disks.
                              Sonos bridge. I'm not even a Sonos user so I'm not exactly sure what it does but I think it's an access point for Sonos devices. Has ethernet in the back. Pulled from the trash from work with no signs of life. Can you spot why? 3 new caps and she's as good as new. Never heard of TBor brand before.
                              Ryzen 3600x
                              16GB Patriot 3600MHz
                              MSI B450 Gaming Plus
                              MSI Air Boost Vega 56
                              Acer 32" 1440P Freesync
                              Rosewill Capstone 750W
                              Hakko FX-888D Station
                              FX-8802 Iron
                              MG Chem .8mm 63/37 RA 2.2%
                                Heh I guess that would automatically be called a worthless/useless repair if one doesn't know what the device does and don't expect to ever use or even test the device
                                  ToBe OR not to be caps
                                    You guys will laugh at this one. Got this old iPitomy phone system from the bin at work. It's basically an intel Atom x86 system with a pico DC-DC power supply. I replaced the motherboard caps that were leaking and some additional with Aliexpress Polys and it works fine.
                                    I troubleshot the power supply for a good month off and on, couldn't figure out why it wouldn't stay running and would go into protection mode. Turns out I was feeding it 19v from a laptop power brick and it needs 12v
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      That's because they are Too Boring.
                                      Though, one of yours looks like it almost launched the way it shot out the bottom away from the bung. I guess that one wasn't too boring. It certainly must have made a small pop doing this.
                                      Well, I think we figured which option those caps chose when they failed.
                                      LOLOLOL. So true.
                                      I guess he can try to sell it online and recoup back the cost of the caps... and maybe enough for a beer too?
                                        But wait, I thought boring was good?
                                        Shouldn't it be extended to individual components on power supplies, if capacitors made noises, flashes, and smell bad, then they would not be boring and hence bad?
                                          Well, I meant as a brand name.
                                          Otherwise, you can see how one of these has popped from its bottom. I'm sure it must have made at least a "muffled" pop inside the case. Definitely NOT boring!
                                          What's if it's a Rubycon cap with custom RGB LEDs? That would make it not boring (according to "gamer kids" today) and still good?
