pls Schematic for hp 15-d041TU
    the mother number is
    osamu2_BT_HPC MV_MB_v1
    Re: pls Schematic for hp 15-d041TU
    enjoy
      many....many ...thanks
        mr highpulse
        i have found in pin 1 and pin 8 1.8volt and i must found 3.3v
        i dont know why ؟
          Originally posted by highpulse View Post
          enjoy
          I have flash it but the same problem no power
          i need schematics pls
            no KADI .
            2 problems
            first to reflash this bios , you flasher must support 1.8volts bios , if not you must make or buy a adapter and chek if your flasher database is up to date .
            in your case the bios will be feeded at 1.8 volts so everything is ok here .
            now when you flashed the bios , everything was ok ? no errors ?
              Thank you very much for the file
                Does anyone have a schematic please.
                  Pls hp 15 (da0u81mb6c0)no power on the board I have changed charger but still no power but the charger works on different laptop I have remove the board but I don't know where to start looking for the problem please help me .thanks in advance
                  I have checked the power Jack is working well.
                    Mido1, you need to learn how a computer starts up. Look for start up sequence or power-on sequence of a laptop on youtube. Excellent video in Spanish is here:
                    https://www.youtube.com/watch?v=OAA74zy-lzI
                    There are others in English but hard to understand, strong Indian accent.:
                    https://www.youtube.com/watch?v=BrsZGFCIqrY
                      Thanks for the reply it really helped.
                        need OSAMU2_DIS_KB_HPC schematic please
                          Gracias
                            enjoy
                            plese schematic
                              Originally posted by kavinda View Post
                              plese schematic
                              Unavailable
                                I need the hp 15- d041TU layout. Please, can someone help me
                                  thanks my sweet hearttttttttttttt
                                    available????? schematics for it
                                      schematics ????????????
